| need rom for wd2500aajs-00yzca0 http://forum.hddguru.com/viewtopic.php?f=7&t=26575 |
Page 1 of 1 |
| Author: | longlife [ August 4th, 2013, 22:20 ] |
| Post subject: | need rom for wd2500aajs-00yzca0 |
any one having the firmwire pl give link |
| Author: | labtech [ August 8th, 2013, 8:38 ] |
| Post subject: | Re: need rom for wd2500aajs-00yzca0 |
Have you checked in the firmware section, yet? |
| Author: | hddguy [ August 8th, 2013, 11:12 ] |
longlife wrote: any one having the firmwire pl give link 90% of the time the specific revision is required, and in case of inexperience probably a similar percentage of cases do not even have problems with the ROM. What is wrong with your hdd? does it power? does it make any sounds? do you see any ATA registers? What work have you tried already? And is data important? |
