Tools for hard drive diagnostics, repair, and data recovery
November 26th, 2013, 23:49
Head Map on ROM one drive have 5 heads the other have 6.
That is why NO SA access !!!!!
Mistery solved
Best regards.
November 27th, 2013, 0:03
Were you able to recover the data?
November 27th, 2013, 0:12
fzabkar wrote:Were you able to recover the data?
Nope !
Couldn't write correct ROM to PCB. PC crashed with blue-screen when WDR tries to write ROM on that PCB.
Was talking with OP on Skype and he will buy correct PCB for the drive and Willem external programmer.
For some reason writting ROM with WDR sometimes it's not a good idea .... It tends to not work properly.
November 28th, 2013, 9:34
Was watching patiently the thread and was surprised as Mr. spildit was using teamviewer to correct the rom.
But what will happen now? Will Op write the rom with Wiiliam programmer. How Op will get the correct rom to program externally?
what is the procedure for writing the rom with programmer?
November 28th, 2013, 19:06
longlife wrote:Was watching patiently the thread and was surprised as Mr. spildit was using teamviewer to correct the rom.
I've made a backup of the ROM on the first place.
WDR crashed / Windows crashed so the ROM eneded up damaged (on drive).
Now OP will have to wait for the willem to arrive to connect it to the ROM chip of the PCB and get the ROM.bin that i left on the desktop flashed on the ROM Soic8 chip.
Also that ROM was already NOT NATIVE for the drive, so correct ROM have to be made by using the correct set of adaptives on a ROM of the same firmware version of the Drive.
November 29th, 2013, 8:24
Hello everyone, I was looking on the net for the PCB for this drive, and something possessed me to once again enter the numbers of stickers, and unfortunately came out, I was mistaken with another model, plate number 2061-771640-M03 AB, we have it by ebay is the correct PCB for this drive model, And I have to tell you that I managed to persuade parents to Willem programmer latest version available, useful for recording the appropriate file ROM.bin and programmed several churches Flash BIOS, in Friday or a Monday for me to be with me, and I think that this together to succeed.
November 29th, 2013, 19:28
pikus_09 wrote:Hello everyone, I was looking on the net for the PCB for this drive, and something possessed me to once again enter the numbers of stickers, and unfortunately came out, I was mistaken with another model, plate number 2061-771640-M03 AB, we have it by ebay is the correct PCB for this drive model, And I have to tell you that I managed to persuade parents to Willem programmer latest version available, useful for recording the appropriate file ROM.bin and programmed several churches Flash BIOS, in Friday or a Monday for me to be with me, and I think that this together to succeed.
Ok !
Let me know when the parts arrive.
I will be on Skype. We can try to fix ROM or adapt ROM.
Best regards.
November 30th, 2013, 8:48
Ok, I suspect that on Monday will be the programmer, cramps himself did not want to believe that this unlucky PCB is correct. Gee I do not know how to repay you Spildit colleagues, and others who have visited my topic for your time, only what I can from each other, write it from the heart THANK YOU!.
November 30th, 2013, 11:10
pikus_09 wrote:Ok, I suspect that on Monday will be the programmer, cramps himself did not want to believe that this unlucky PCB is correct. Gee I do not know how to repay you Spildit colleagues, and others who have visited my topic for your time, only what I can from each other, write it from the heart THANK YOU!.
No problem.
Let me know when the programmer arrives.
Regards.
November 30th, 2013, 18:21
Ok, so as I wrote, the programmer will be on Monday ie 02.12.2013r so provides mail that I received from the courier;)
November 30th, 2013, 19:16
pikus_09 wrote:Ok, so as I wrote, the programmer will be on Monday ie 02.12.2013r so provides mail that I received from the courier;)
Ok.
Can you unsolder the ROM chip from the pcb to programm ?
If not you might need the SOIC8 clip.
Check PCB for ROM chip (8 leg SOIC8).
November 30th, 2013, 19:34
This Chip is SOIC8. So I then solder system. It has the Hot Air. On the other hand adapter to SOIC8 already have drawn enough etched in B327. So that no problem;)
November 30th, 2013, 20:50
pikus_09 wrote:This Chip is SOIC8. So I then solder system. It has the Hot Air. On the other hand adapter to SOIC8 already have drawn enough etched in B327. So that no problem;)
Great !
Skype me when the Willem arrives and i will take a look at the drive again by Teamviewer.
We can flash back the ROM that was damaged and start all over again.
Let's hope that we can fix it this time.
December 1st, 2013, 8:28
Okay, tomorrow we will act at will
, and I hope it will work, btw how will it cramp willem we shall be able to practice hard all you want
Spildit buddy, with your help, I'm sure that the HDD will return to the world of the living. And my question is whether the subject is in a good section? Does not affect the forum rules? As you have you convinced I am of Polish and are backed by some google translator. And if somehow violates the rules he asked me to transfer this topic in other more appropriate place to make it well.
December 1st, 2013, 10:26
pikus_09 wrote:Okay, tomorrow we will act at will
Don't worry. If it's out of plave the topic will be moved. It's ok.
I will be at skype tomorrow at the usual time then.
December 1st, 2013, 18:08
Ok, while I'll let you know via Skype when I'm ready for action. You know buddy to help parents.
December 1st, 2013, 21:57
pikus_09 wrote:Ok, while I'll let you know via Skype when I'm ready for action. You know buddy to help parents.
Ok then. Talk tomorrow (monday).
December 3rd, 2013, 18:03
Hello, in particular, buddy spildit Willem version 7.1 on the LPT port is already in me (
http://www.gotronik.pl/programatory/willem7.html, will be good?), The site is in Polish so I suggest you use google translator. Colleague Spildit, fiddling with the drive we need to put down on a Saturday because I work at my father's car, do not think of myself that I bailed case, I have it in mind, but also have domestic responsibilities.
December 3rd, 2013, 19:07
pikus_09 wrote:Hello, in particular, buddy spildit Willem version 7.1 on the LPT port is already in me (
Yes, that Willem 7 will do !
Saturday then, Skype me when you are available. We will try to make the drive work again then, I will be at skype.
Best regards and have a nice week and take good care of father's car !
December 4th, 2013, 6:56
Ok, we will be in touch
