Tools for hard drive diagnostics, repair, and data recovery
Re: Need firmware for WD15EADS-22P8B0
December 8th, 2013, 17:37
hey spildit buddy, we must unfortunately leave some time to play with the drive until I find a new bone PM25LV020, ehh lot narobiło, that I tried to upload a file ROM.bin you did with my copy of this disc Willem, but unfortunately, the bone through manipulation and fun was damaged electrically and mechanically (been broken individual pins) itself is efficient drive electronics are not damaged pads. I hate to ask, but if he could colleague would have the memory of home in their resources (if only friend has this type of resources). I hope that this information will not discourage buddy for further assistance with this disc.
December 8th, 2013, 17:47
Hi there !
I'm sorry to know that the ROM chip ended damaged.
But yes, i will wait untill you manage to find a replacement and then we can continue on.
I will be here and try to assist the best that i can.
Contact me by Skype anytime, or here by PM.
Best regards !
December 13th, 2013, 15:25
hello everyone, Ok, chip SPI to me it is already going to the stables winbond W25X20, it is a replacement but 100% compatible with the original PM25LD020. On Monday we shall try again to upload the file ROM.bin in programmer;)
Ps. as is already uploaded the file, and all filed together then I'll talk to you on skype buddy Spildit ok?
December 13th, 2013, 20:11
pikus_09 wrote:hello everyone, Ok, chip SPI to me it is already going to the stables winbond W25X20, it is a replacement but 100% compatible with the original PM25LD020. On Monday we shall try again to upload the file ROM.bin in programmer;)
Ok !
December 16th, 2013, 16:03
Hello everyone, Hard Disk working, so that Spildit buddy if you are not discouraged invite you to Teamviewer, Skype. It will not disturb fellow Polish version of Windows XP?
December 19th, 2013, 10:59
If anyone else besides colleague splidit could be treated with this drive!? If this is not no problem :)
December 21st, 2013, 21:25
This is what I could figure out from your drive :
- The drive have a wrong Head Map or one head was already depoped.
Loading a Head Map from a donor drive of the same model as yours show that Head 3 Should be enabled, while on your drive it isn't the case. Trying to correct it and the Native Map / Good Map values doesn't make any difference regarding the drive situation.
- Can't read a single FW module on the 2nd copy (head 1).
- I can Read and DUMP a FEW (very few in fact) modules on SA, leading to believe that some SA modules can be read, so the information on ROM is correct, allowing for Module access, and the problem might be BAD Sector on SA tracks, or Tracks on SA can't be read due to MEDIA DAMAGE ?
- Writing to modules "appears" to work but when checking again they are still BAD and can't be READ. It's like writing to a bad spot on the drive.
As you don't need data from the drive, and the drive already have one head less than it apparently should, I wouldn't be wasting more time with this drive and would buy another one.
As a last effort I would try to format SA and copy new compatible modules, run ARCO, Run SS, pray allot ..... and hopefully it would kill the drive anyway .... really, it's not worth the trouble and the drive would never be reliable again.
The fact that I can read at least 4 or 5 modules and valid data is present inside them indicates to me that there is no problem with the ROM head Map or SA address, in other words, the drive can find the location of the modules on the platter, but simply can't read them because the SA tracks are bad. This is what I think anyhow. I don't think that anyone would have messed with the drive at a firmware level, like editing the firmware region map ..... My guess is that something BAD happened like drive was dropped and heads hit platter damaging SA tracks .....
I'm very sorry but at this point there is nothing more then I can do.
Maybe someone else with more experience might assist you.
Best regards.
December 22nd, 2013, 10:33
Hey, Spildit. I think I know where the devil is, and so the problem probably is not BAD sectors in SA, the problem is in the ROM, because why I drew, because the system rom how the soldered it W25X020, and the original original, which was a PM25LD020, which is vaguely different than W25X020 , If it were indeed Bad sectors in SA, or a problem with the heads, it would be difficult to have access to the BIOS level, or drive by trapping heads. Here it is not, I think after the new year, how do I get PM25LD020 (primary IC ROM), this reading of the modules will be enabled.
December 28th, 2013, 11:16
Hey everyone.
I apologize in advance that this post under the post, but ran out of time to edit the previous one. So yes, I attach files from the action on the disk. In the file. zip are two folders in the folder where the files are located Work1_old of the previous attempts of the IC PM25LD020, while work1 folder contains the files of the current sample with the IC W25X020. Regards!
:arrow: If my English is not understandable, please write. I recall my English is based mostly on the basis of google translator. Because, I come from Poland.
WD15EADS-22p8b0.part03.rar
(2.33 MiB) Downloaded 430 times
WD15EADS-22p8b0.part02.rar
(5 MiB) Downloaded 442 times
WD15EADS-22p8b0.part01.rar
(5 MiB) Downloaded 431 times
December 31st, 2013, 11:11
If anyone has anything to add to this topic, the invite :)
Btw: Continuing this thread is at this link: http://malthus.zapto.org/viewtopic.php? ... 1&start=20
January 19th, 2014, 8:46
Hello Spildit, If you have the time and inclination to play the HDD, I'm waiting for you with open arms, and I'm almost always online. It's no problem. :)
December 10th, 2014, 19:14
HDD Is working fine after 1.5 years fighting with the repair, Attach SMART.
