Significance of module 11 in WDR
Posted: January 15th, 2014, 9:23
by longlife
I was working with wdr 4.00 but could not succeed in writing module in replacement PCB. Is there any significance of module ~id11 in wdr.
How i can be confirmed that the modules are right for the HDD.
Also, can any guru describe the process of writing module in replacement PCB.
Salute to gurus in advance.
Re: Significance of module 11 in WDR
Posted: January 15th, 2014, 9:49
by Doomer
Mod11 is practically like a kernel to OS, so it is important. You can't write it to PCB because it's not supposed to be in PCB - it resides on platters
Posted: January 18th, 2014, 16:01
by BGman
longlife wrote:I was working with wdr 4.00 but could not succeed in writing module in replacement PCB. Is there any significance of module ~id11 in wdr.
It seems like written in English, but I can understand almost nothing of your question...
Posted: January 18th, 2014, 23:10
by longlife
BGman,
I was working for quite time with wdr 6.00, but without any success. I was thinking was my process for writing rom in replacement PCB WRONG?? is there any way i can use the module 11??
Posted: January 18th, 2014, 23:19
by fzabkar
You can sometimes regenerate the ROM from MOD 109 plus a few others.
Regenerating a WD ROYL ROM from SA MODs:
http://malthus.zapto.org/viewtopic.php? ... 2710#p2710
Posted: January 19th, 2014, 15:43
by BGman
The rule is that ROM and the FW modules should belong to the same firmware revision. If you try to load in memory Permanent Overlay (mod 11) from a different revision it will cause debug stop and the drive will RESET.
This is a general answer to your general question.
If you need a real help put here all details about your drive, otherwise nobody could even try to help you . Keep in mind that the solution might be different for different drive families.
Posted: January 20th, 2014, 21:51
by longlife
ok i shall be posting snapshots of my drive with WDR 2moro.
