 Post subject: Significance of module 11 in WDR
PostPosted: January 15th, 2014, 9:23
I was working with wdr 4.00 but could not succeed in writing module in replacement PCB. Is there any significance of module ~id11 in wdr.
How i can be confirmed that the modules are right for the HDD.
Also, can any guru describe the process of writing module in replacement PCB.
Salute to gurus in advance.
 Post subject: Re: Significance of module 11 in WDR
PostPosted: January 15th, 2014, 9:49
Mod11 is practically like a kernel to OS, so it is important. You can't write it to PCB because it's not supposed to be in PCB - it resides on platters
PostPosted: January 18th, 2014, 16:01
It seems like written in English, but I can understand almost nothing of your question... :shock:
PostPosted: January 18th, 2014, 23:10
BGman,
I was working for quite time with wdr 6.00, but without any success. I was thinking was my process for writing rom in replacement PCB WRONG?? is there any way i can use the module 11??
PostPosted: January 18th, 2014, 23:19
You can sometimes regenerate the ROM from MOD 109 plus a few others.
Regenerating a WD ROYL ROM from SA MODs:
http://malthus.zapto.org/viewtopic.php? ... 2710#p2710
PostPosted: January 19th, 2014, 15:43
The rule is that ROM and the FW modules should belong to the same firmware revision. If you try to load in memory Permanent Overlay (mod 11) from a different revision it will cause debug stop and the drive will RESET.
This is a general answer to your general question.
If you need a real help put here all details about your drive, otherwise nobody could even try to help you . Keep in mind that the solution might be different for different drive families.
PostPosted: January 20th, 2014, 21:51
ok i shall be posting snapshots of my drive with WDR 2moro.
Users browsing this forum: No registered users and 14 guests
