| Data Recovery from 2 HDD Using RAID Level 0 http://forum.hddguru.com/viewtopic.php?f=7&t=27900 |
Page 1 of 1 |
| Author: | angelh55 [ February 5th, 2014, 18:32 ] |
| Post subject: | Data Recovery from 2 HDD Using RAID Level 0 |
Hi guys I've been working on this problem on and off for a few months. I can really use your help. Maybe I'm over-looking the obvious. I am using a Buffalo LS-W2.0TGL/R1 2TB LinkStation Pro Duo Network Storage on my network. Using RAID Level = 0. It has lost it's partition info, but all the data is still there on both drives. I'm using iCare Data Recovery Enterprise Version 5.1 Software to view the files. Here's the part I'm stuck at. Since each file is split between drive A and drive B. I can retrieve RAW data from one drive at a time, but I end up with only half the document, video, audio, & photo file. I can't find where in iCare Data Recovery to look in both drives so I can recovery every file and not just half of a file. How can I recover both halves from both HDD at the same time? And view the entire photos. All documents, videos, and audio files can not be opened. saying "corrupted data." Which I know it means I only have half of a file. Please let me know if there is a way to recover all files from 2 drives. Either using iCare Data Recovery or a better recommended software. I have a new 3TB internal HDD in my PC that I waiting to recover the lost files to. Running Windows 7 (64-bit O/S) AMD FX 4 (3.2Ghz) CPU 16GB RAM I really would appreciate your help in recovery this lost data. I've been going through the forum and have yet to find a similar post. If you know of a similar post please point me in the right direction. Thank you |
| Author: | DrFaustus [ February 6th, 2014, 0:03 ] |
| Post subject: | Re: Data Recovery from 2 HDD Using RAID Level 0 |
try http://www.diskinternals.com/raid-recovery/ in the demo ware you cant export files, but you can export and image of the assembled volume.... then run your icare on that |
| Author: | sosrecup [ February 12th, 2014, 4:11 ] |
does the drives have any physical damage? I had a similar case. the best way to handle this issue is to image the 2 drives and work on the images not on the physical drives. then use a software like R-studio to reconstruct your RAID array. |
