I was imaging a heap of new dell Optiplex PCs at work today and came across some interesting utilities and manuals that are helpful in explaing and working with AF drives.
The first one is a simple util called "Dell Advanced Format HDD Detection Tool Utility"and it is a Command Line Utility(elevation required). Basically prints out details of how the disk is configured relating to AF, and alignment. Output like:
C:\Users\admin\Desktop\DELL_ADVANCED-FORMAT-HDD-DET_A00_R306204>DellAFDT.exe
Model: Hitachi HDS721616PLA380
Serial#: PVF90XXXXX346N
Advanced Format: No
Partition Alignment: Aligned
Partition 1: Aligned [C:]
Identify Data Word 106: 0x0
Identify Data Word 117: 0x0
Identify Data Word 118: 0x0
Identify Data Word 209: 0x0
Model: ST3250312AS
Serial#: 5VY5XXXX
Advanced Format: No
Partition 1: Aligned [D:]
Second one is "Paragon Alignment Tool Utility"
havent looked at it much as I dont plan to play with the disks in these PCs but the docs are pretty interesting if you havent seen much about AF and want to get a handle on it. The disk test in the docs is particularly interesting as the speed is a dramatic change if the alignment is correct.
from "Why alignment of extended partitions is not necessary - statement.pdf"
Simple test:
1. Writing 15GB of data (154 files x 100MB each) from ALIGNED PRIMARY partition to UNALIGNED LOGICAL partition, located within UNALIGNED EXTENDED partition. Complete time: 23 min 53 sec.
2. Writing 15GB of data (154 files x 100MB each) from ALIGNED PRIMARY partition to ALIGNED LOGICAL partition, located within UNALIGNED EXTENDED partition. Complete time: 14 min 48 sec.
3. Writing 15GB of data (154 files x 100MB each) from ALIGNED PRIMARY partition to ALIGNED LOGICAL partition, located within ALIGNED EXTENDED partition. Complete time: Complete time: 14 min 49 sec.
a good explanation of alignment and Advanced Format is in the docs:
The software was available on dell site optiplex 3010. May work on other systems, but as always, read the T & C, YMMV, You break it, you bought it and wear a condom.
Dell Specific Paragon Alignment Tool Utility filename: PARAGON-SOFTWARE-GROUP_HDD-T_A01_R306379.exe
folders:Recovery CD Image
User Manuals & FAQs Docs
Windows Installation Package
Dell Advanced Format HDD Detection Tool Utility : DELL_ADVANCED-FORMAT-HDD-DET_A00_R306204.exe
I thought the info may be enlightening for non-gurus like me out there, EnjoY !
