HDD GURU FORUMS
http://forum.hddguru.com/
WD3200AAKS-75L9A0 flashed with wrong fw version
http://forum.hddguru.com/viewtopic.php?f=7&t=28286
Page 1 of 1
Author:  wizz [ March 30th, 2014, 9:28 ]
Post subject:  WD3200AAKS-75L9A0 flashed with wrong fw version
after After replacing the board WD3200AAKS-75L9A0,flashed with wrong fw version(from tornado 2d).
How do I restore the original firmware (192kb) which I have (pinaclelite),with WDR, or some tips with jumpers...
Author:  longlife [ March 30th, 2014, 23:32 ]
Post subject:  Re: WD3200AAKS-75L9A0 flashed with wrong fw version
Before we sit down to analyse, please say which version of wdr has been used and what is hdd's module u have flashed.
Author:  wizz [ April 5th, 2014, 3:33 ]
I have version 3.0. Wrong firmware (flashed)=WD3200AAKS-00VYA0_12.01B02 (587S.bin), need to reflash with WD3200AAKS-75L9A0 (01CS.bin),The first thing I want to know,can I rewrite the firmware with a setting Jumer or through the serial port, there are probably serial pins as Samsung or Seagate,
Author:  longlife [ April 6th, 2014, 6:45 ]
Have u tried reflashing with wdr + WD3200AAKS-75L9A0. wdr needs no jumper or serial port like sasung or seagate.
Author:  wizz [ April 6th, 2014, 9:02 ]
yes, and interesting, always is the same: "Erase Flash - FFFF=NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG" folowing with: "Write Flash - FFFF=NOT_AN_ERR_VSC_CMD_EXEC_IN_BKG", but nothing happens with rom in backgroud "IN BKG"
Author:  BGman [ April 15th, 2014, 16:38 ]
Wrong. Jumpers have to be set in order to start the drive in safe mode.
Author:  longlife [ April 20th, 2014, 10:07 ]
Thanx bgman for the information.
What i know is win WDR5.3 no jumper setting is necessary. Will u please clarify for knowledge sake.
Author:  BGman [ May 17th, 2014, 10:39 ]
To flash a new ROM to a drive you need the drive to be in "safe" mode.
The easiest way to set a drive in safe mode is by using jumpers.
http://www.phpbb.com/
