 Post subject: HDD Serial number change/spoof
PostPosted: April 4th, 2014, 11:29
I've been digging google and searching tool that is able to change/spoof serial number(not volumeid), doesn't cost 500€ and works under 64bit systems. It's time to write there. Do any of you(users) have such software?
Thanks in advance
 Post subject: Re: HDD Serial number change/spoof
PostPosted: April 4th, 2014, 14:34
There are several programs/methods. Which model are you interested in?
PostPosted: April 4th, 2014, 18:56
Hello once again,
My HDD is:
PostPosted: April 5th, 2014, 18:48
I think you should be looking for SRT.
PostPosted: April 5th, 2014, 19:26
There are several tools such as SalvationData, can you recommend me some?
Also, is it dangerous (changing such serial number)?
PostPosted: April 5th, 2014, 19:39
Changing the serial number entails writing to the firmware area of a HDD. That has finite risks. Also, some of the tools are of a dubious nature and may not work as claimed. If you want professional tools, then others would be best placed to advise you. I'm not a data recovery professional.
