 Post subject: wd3200bevt-75a23t0
PostPosted: April 20th, 2014, 6:36
hi to all friends,
dears i have search a lot but no post match with my case so that i m posting new thread.
dear friends i had a laptop DELL inspiron N4050 i was locked my drive with password and it was remembered me when i used it. then my laptop burnt and no more then i remove its harddrive and connect to pc but password forgeted please friends help me to remove password from it. model is wd3200bevt-75a23t0.
thanks
 Post subject: Re: wd3200bevt-75a23t0
PostPosted: April 21st, 2014, 13:28
I realize English must not be your first language, so hopefully we can communicate. If you're referring to a factory lock code on the hard drive, then you will need special equipment to remove the password without erasing the data. There is software that can do it for some models, but I've never used it.
I recommend you seek out a professional data recovery company in your area. They shouldn't charge a large sum of money to just run an unlock. If you tell me where you're located perhaps I can recommend a good company.
