| Tool to move the clusters/sectors for a file http://forum.hddguru.com/viewtopic.php?f=7&t=28473 |
Page 1 of 1 |
| Author: | chcw [ April 25th, 2014, 21:54 ] |
| Post subject: | Tool to move the clusters/sectors for a file |
I know when a file is allocated on a file system, such as NTFS or FAT32, the file system will allocated some clusters/sectors for it. After the file is allocated, is there a tool that can move the clusters allocated to the file from one location to another, and update the file system meta data as well? This is just like a defragment for a file manually. |
| Author: | ReclaiMe [ April 27th, 2014, 8:19 ] |
| Post subject: | Re: Tool to move the clusters/sectors for a file |
If you want to defragment a single file, CONTIG from SysInternals does it. technet.microsoft.com/en-us/sysinternals/bb897428.aspx |
| Author: | chcw [ April 27th, 2014, 9:50 ] |
It seems that CONTIG is a commandline tool, not GUI based? |
| Author: | ReclaiMe [ April 27th, 2014, 11:23 ] |
Correct. |
| Author: | HaQue [ April 27th, 2014, 22:45 ] |
does the OP want to also specify where the file is now located? I dont think Contig does that. |
| Author: | chcw [ April 28th, 2014, 9:44 ] |
Yes, I do want to do so. Thank. |
| Author: | HaQue [ April 28th, 2014, 10:36 ] |
Can you code? I don't think it would be that difficult to write a util to do it |
