 Post subject: Will this cable work with this hard drive?
PostPosted: May 3rd, 2014, 5:08
Hi there,
I need to get stuff from my hard drive onto my computer, and I'm not sure whether this cable:
http://www.ebay.co.uk/itm/USB-to-SATA-Serial-ATA-15-7-22P-Adapter-Cable-For-2-5-Laptop-Hard-Drive-HDD-SSD-/190698939490
...will work with my hard drive.
It came out of my old MacBook Pro
120GB
It says SATA on it somewhere
The connexions are a set of 15 gold plated contact points in a line (I presume is for power) and a shorter line next to that of 7 contact points (I presume is for data)
It is made by Fujitsu
The connections look like this from the end
-------------¬ ı-------
It has a diagram saying this:
SATA power serial data
Caution: please attach all cables securely blaa blaa blaa...
Hope someone can help...
Quenton
 Post subject: Re: Will this cable work with this hard drive?
PostPosted: May 3rd, 2014, 19:36
Bigger question is why trying to get files off the drive in thus manner? If it is failed, then using the USB cable is not a good plan.
