| Will this cable work with this hard drive? http://forum.hddguru.com/viewtopic.php?f=7&t=28527 |
Page 1 of 1 |
| Author: | Quenton [ May 3rd, 2014, 5:08 ] |
| Post subject: | Will this cable work with this hard drive? |
Hi there, I need to get stuff from my hard drive onto my computer, and I'm not sure whether this cable: http://www.ebay.co.uk/itm/USB-to-SATA-Serial-ATA-15-7-22P-Adapter-Cable-For-2-5-Laptop-Hard-Drive-HDD-SSD-/190698939490 ...will work with my hard drive. It came out of my old MacBook Pro 120GB It says SATA on it somewhere The connexions are a set of 15 gold plated contact points in a line (I presume is for power) and a shorter line next to that of 7 contact points (I presume is for data) It is made by Fujitsu The connections look like this from the end -------------¬ ı------- It has a diagram saying this: -------------¬ ı------ SATA power serial data Caution: please attach all cables securely blaa blaa blaa... Hope someone can help... Quenton |
| Author: | labtech [ May 3rd, 2014, 19:36 ] |
| Post subject: | Re: Will this cable work with this hard drive? |
Bigger question is why trying to get files off the drive in thus manner? If it is failed, then using the USB cable is not a good plan. |
