 Post subject: STCom Tools bin files
PostPosted: May 17th, 2014, 20:09
Done anyone have a rom.bin from NHAWK2HD - 1_Disk 3.AAC 01-04-07_18:32 AAC,NH_1D_2H_S,6D?
Trying to resurrect an old drive after some experimenting.
I have firmware bin and trc but didn't same the rom :(
Peter
 Post subject: Re: STCom Tools bin files
PostPosted: May 17th, 2014, 22:28
Hi Spildit,
Thanks for the quick reply.
There's no data on the drive so it no supper loss but I would like to resurrect it if I can.
I backed up APP CERT TABLE AT0 and ATA1 from firmware backup and also the full tracks.
I was running an SF extended from stcom tools it stopped at test 99 ^t restarted test 10 and hung.
I then power cycled the drive.
Test sequence is
D
02,83,84,03,06,07,90,93,98,9C,AA,81,09,74,F4,0F,82,94,56,99,
10,11,12,13,14,15,16,17,18,19,1A,1B,1C,1D,1E,2A,DA,DC,D6,D7,
D8,D9,7C,B9,7D,78,58,23,8F,31,AB,32,AB,33,AB,34,AB,36,A8,37,
3A,8A,3B,3C,3D,3E,A9,3F,20,77,9D,74,E0,87,88,41,4B,44,48,49,
53,4A,4D,8B,61,28,62,29,63,59,85,35,6F,4E,00
C>
In hindsight I probably should have attempted to load the tracks back to the drive but...
now it starts as follows
eset
4096k x 16 DRAM
NHAWK - 1_Disk S-41 10-23-06_16:40
Buzz HM SFI
ERR A6: App Code
F>
I tried class F boot but no joy it doesn't seem to get any response from the drive on attempt to upload the firmware too it.
I was thinking perhaps a reload of the rom from the .bin may help to make the class F boot function and allow me to continue- now if only I had backed that up first.
I don't have any serial programmer hardware so its a bit of a hail Mary.
Interestingly this was reporting as
T>Eng Rev = .09H
Compat/Hardware = .6B1
CERT Rev = .063
.063
Mask Rom Rev = S-41
Orig Code = AAC6D0
and now says
Interface is unresponsive to commands and I only get >F after power-cycling twice I suspect it tries to boot firmware fails and goes to F> on next attempt.
The same sequence work a treat to get my two even older ST3160827AS back in the land of the living after a few attempts.
The ST3160815AS ... not so much well so far anyway:)
Peter
PostPosted: May 17th, 2014, 22:49
hmm is seems it needed the sata cable inserted to get response very weird.
Trying a class f boot at 9600 will let you know.
PostPosted: May 18th, 2014, 23:13
Thanks again Splidit,
The f class boot worked with 9600 AP only and the write back to SA selected.
Perhaps it was bad serial connection.
Took a backup of the rom (just in case)
The drive was not behaving too well so I restored all tracks.
Still no joy so another round of tests stopped at test test99 again.
Did another fboot with APP track only and reloaded cert and continued tests with ^t.
Hey presto 14hrs later I reloaded ata and vendor cleared smart.
Drive seems ok so far mhdd with erase waits at 25 ms says no erase waits (but a small number of <50ms blocks).
Next to copy the data back from the two older 160g, a btrfs scrub see how it goes then hand them off to the sprog for her media server.
Now onto the ST3100052AS (7200.12) with a 264 relocated sectors all backuped up to a duplicate drive but would be nice to reattach these as a mirror on my home server after I fix the corrupted btrfs on it.
From reading the forum the F3 drives dont have the self tests, you have to use m0 and care has to be take to use the correct options especially if you want any data (I don't)
It looks like the non resident glist is empty (V40) but the Glist is large (probably full)
F3 T>V4
Reassigned Sectors List
Entries: 0158, Retrieved: 0158, Alts: 0108, Removed: 061B, Pending: 0000, GList: 0108, RList: 0050
does m0,2,2,,,,,22 do a scan and remap which would move any bad sectors in the glist to the plist?
Peter
PostPosted: May 19th, 2014, 22:43
Hi Spildit,
Thanks again for your help it been a bit of fun getting these drives operational again I'm donating the 160s to my daughter for a small media server so no great loss if they die.
I have a badly broken btrfs on the 1T I blanked the first 2G then botched the recovery and have to write some code to recover what I can, that may be of some use but its a bit specific.
Not sure what I can share that's of any use to anyone in here.
1 check cables are connected properly
2 think twice or more before typing
I did try the ^t originally but perhaps I was impatient and did something else but I recall it hanging.
On the 1T 7200.12, it had an empty nrg, I did 1 run of the cosmetic fix using st tools f3 menu: g->p, fix .12, erase glist, erase smart .
The other buttons in the fix section (m0 with other options did not work)
Then I ran mhdd on it. It looks like I needed to write to it first and before doing a check so I did a fast erase then a scan with 1 sec wait and 25ms erase waits (not may blocks in the <50ms and a few erase waits). A smart self test passed.
As I ran a scan first it generated a few errors but seems to be OK.
Not sure I should redo this to get rid of the Reported Uncorrect 11.
Great pitty there's no full SS fo the drive:(
for d in sd{a,b} ;do smartctl -iAl error /dev/$d |awk '$NF != "0" {print}';done
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.14.4-1-ARCH] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family:     Seagate Barracuda 7200.12
Device Model:     ST31000528AS
Serial Number:    9VP40ANE
LU WWN Device Id: 5 000c50 01a7870a5
Firmware Version: CC49
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    7200 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 2.6, 3.0 Gb/s
Local Time is:    Mon May 19 19:32:03 2014 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   117   100   006    Pre-fail  Always       -       120214022
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       14
  7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always       -       11450
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       16
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       7
187 Reported_Uncorrect      0x0032   089   089   000    Old_age   Always       -       11
188 Command_Timeout         0x0032   100   001   000    Old_age   Always       -       8590393648
189 High_Fly_Writes         0x003a   097   097   000    Old_age   Always       -       3
190 Airflow_Temperature_Cel 0x0022   067   063   045    Old_age   Always       -       33 (Min/Max 22/35)
194 Temperature_Celsius     0x0022   033   040   000    Old_age   Always       -       33 (0 22 0 0 0)
195 Hardware_ECC_Recovered  0x001a   036   035   000    Old_age   Always       -       120214022
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       142326626254873
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       1967191209
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       1400891258
SMART Error Log Version: 1
ATA Error Count: 6 (device log contains only the most recent five errors)
   CR = Command Register [HEX]
   FR = Features Register [HEX]
   SC = Sector Count Register [HEX]
   SN = Sector Number Register [HEX]
   CL = Cylinder Low Register [HEX]
   CH = Cylinder High Register [HEX]
   DH = Device/Head Register [HEX]
   DC = Device Command Register [HEX]
   ER = Error register [HEX]
   ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 6 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  When the command that caused the error occurred, the device was active or idle.
  After command completion occurred, registers were:
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  Commands leading to the command that caused the error were:
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  42 00 ff ff ff ff ef 00      00:14:05.740  READ VERIFY SECTOR(S) EXT
  00 00 00 00 00 00 00 04      00:14:04.136  NOP [Abort queued commands]
  42 00 ff ff ff ff ef 00      00:14:03.091  READ VERIFY SECTOR(S) EXT
  00 00 00 00 00 00 00 04      00:14:01.478  NOP [Abort queued commands]
  42 00 ff ff ff ff ef 00      00:14:00.433  READ VERIFY SECTOR(S) EXT
Error 5 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  40 51 00 fc 03 00 00  Error: UNC at LBA = 0x000003fc = 1020
  42 00 ff fc 03 00 e0 00      00:00:29.325  READ VERIFY SECTOR(S) EXT
  42 00 ff fd 02 00 e0 00      00:00:26.635  READ VERIFY SECTOR(S) EXT
  42 00 ff fe 01 00 e0 00      00:00:23.996  READ VERIFY SECTOR(S) EXT
  42 00 ff ff 00 00 e0 00      00:00:21.265  READ VERIFY SECTOR(S) EXT
  42 00 ff 00 00 00 e0 00      00:00:18.666  READ VERIFY SECTOR(S) EXT
Error 4 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  40 51 00 fd 02 00 00  Error: UNC at LBA = 0x000002fd = 765
  70 00 00 01 00 00 00 00      00:00:18.544  SEEK [OBS-7]
Error 3 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  40 51 00 fe 01 00 00  Error: UNC at LBA = 0x000001fe = 510
  10 03 01 01 00 00 00 00      00:00:16.518  RECALIBRATE [OBS-4]
Error 2 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
  40 51 00 ff 00 00 00  Error: UNC at LBA = 0x000000ff = 255
  00 00 00 00 00 00 00 04      00:00:16.468  NOP [Abort queued commands]
Serial Number:    9VP435LW
LU WWN Device Id: 5 000c50 01a7e5d67
  1 Raw_Read_Error_Rate     0x000f   115   099   006    Pre-fail  Always       -       94001651
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       517
  7 Seek_Error_Rate         0x000f   077   061   030    Pre-fail  Always       -       56642690
  9 Power_On_Hours          0x0032   080   080   000    Old_age   Always       -       17785
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       252
183 Runtime_Bad_Block       0x0032   099   099   000    Old_age   Always       -       1
188 Command_Timeout         0x0032   100   097   000    Old_age   Always       -       12885295132
189 High_Fly_Writes         0x003a   099   099   000    Old_age   Always       -       1
190 Airflow_Temperature_Cel 0x0022   068   057   045    Old_age   Always       -       32 (Min/Max 24/33)
194 Temperature_Celsius     0x0022   032   043   000    Old_age   Always       -       32 (0 19 0 0 0)
195 Hardware_ECC_Recovered  0x001a   047   011   000    Old_age   Always       -       94001651
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       4
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       69106023810955
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       2021231881
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       474301377
No Errors Logged
160g drives looking good so far 1 relocation no errors.
[code]
for d in sd{a,b,c} ;do smartctl -iAl error /dev/$d |awk '$NF != "0" {print}';done
Model Family: Seagate Barracuda 7200.10
Device Model: ST3160815AS
Serial Number: 5RA0FY5F
Firmware Version: 3.AAC
User Capacity: 160,041,885,696 bytes [160 GB]
ATA Version is: ATA/ATAPI-7 (minor revision not indicated)
Local Time is: Mon May 19 19:17:46 2014 PDT
1 Raw_Read_Error_Rate 0x000f 117 100 006 Pre-fail Always - 131546865
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 10
7 Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 872353
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 10
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 10
190 Airflow_Temperature_Cel 0x0022 060 055 045 Old_age Always - 40 (Min/Max 25/41)
194 Temperature_Celsius 0x0022 040 045 000 Old_age Always - 40 (0 25 0 0 0)
195 Hardware_ECC_Recovered 0x001a 088 077 000 Old_age Always - 123880766
No Errors Logged
Model Family: Seagate Barracuda 7200.7 and 7200.7 Plus
Device Model: ST3160827AS
Serial Number: 3MT03NDZ
Firmware Version: 3.42
ATA Version is: ATA/ATAPI-6 T13/1410D revision 2
1 Raw_Read_Error_Rate 0x0000 058 052 000 Old_age Offline - 44545141
4 Start_Stop_Count 0x0000 100 100 000 Old_age Offline - 35
5 Reallocated_Sector_Ct 0x0000 100 100 000 Old_age Offline - 1
7 Seek_Error_Rate 0x0000 066 060 000 Old_age Offline - 4410619
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 65
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 59
194 Temperature_Celsius 0x0000 041 044 000 Old_age Offline - 41 (0 19 0 0 0)
195 Hardware_ECC_Recovered 0x0000 058 051 000 Old_age Offline - 44545141
No Errors Logged
Serial Number: 3MT03ZAV
1 Raw_Read_Error_Rate 0x0000 062 051 000 Old_age Offline - 102058647
4 Start_Stop_Count 0x0000 100 100 000 Old_age Offline - 25
7 Seek_Error_Rate 0x0000 067 060 000 Old_age Offline - 5283178
9 Power_On_Hours 0x0000 100 100 000 Old_age Offline - 74
12 Power_Cycle_Count 0x0000 100 100 000 Old_age Offline - 36
194 Temperature_Celsius 0x0000 045 049 000 Old_age Offline - 45 (0 17 0 0 0)
195 Hardware_ECC_Recovered 0x0000 062 051 000 Old_age Offline - 102058647
No Errors Logged
[code]
PostPosted: May 19th, 2014, 23:43
Hi Spildit,
Thanks again for your help.
Not sure what happened to my last post it seems to have on appeared on the forum.
The 160G drives seem to be doing OK with only 1 relocation.
Local Time is:    Mon May 19 20:33:55 2014 PDT
  7 Seek_Error_Rate         0x000f   100   253   030    Pre-fail  Always       -       892465
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       11
195 Hardware_ECC_Recovered  0x001a   088   077   000    Old_age   Always       -       124684994
No Errors Logged
  1 Raw_Read_Error_Rate     0x0000   057   052   000    Old_age   Offline      -       152273780
  7 Seek_Error_Rate         0x0000   066   060   000    Old_age   Offline      -       4520518
  9 Power_On_Hours          0x0000   100   100   000    Old_age   Offline      -       67
195 Hardware_ECC_Recovered  0x0000   057   051   000    Old_age   Offline      -       152273780
No Errors Logged
  1 Raw_Read_Error_Rate     0x0000   061   051   000    Old_age   Offline      -       215682178
  7 Seek_Error_Rate         0x0000   067   060   000    Old_age   Offline      -       5392816
  9 Power_On_Hours          0x0000   100   100   000    Old_age   Offline      -       75
195 Hardware_ECC_Recovered  0x0000   061   051   000    Old_age   Offline      -       215682178
No Errors Logged
I did the m0,2 clear glist, clear smart on 1T F3 drive.
I looks like you have to write to the drive before doing a scan.
I did a fast erase after finding this out then a mhdd scan with 1 sec wait and 25ms erase waits.
I have cloned my 1T of broken btrfs back to it now I have to write the code to do the recovery from leaf nodes as none of the btrsf tools can access it even a chunk-recover fails :(
It seems OK the errors are from my attempted scan after the stools changes so perhaps I should redo that at least there is room to do some relocations if it needs to.
I've taken to mirroring everything I can these days :)
No Errors Logged
Peter
PostPosted: May 20th, 2014, 4:49
Hi Here's and interesting observation.
smart tests hang on
After the SS i did.
https://bugzilla.redhat.com/show_bug.cgi?id=503344
used a selective smartscan to 'unstick' the smart selftest
short offline is now progressing but seems way slow but no longer stuck at 90%
I will try a long test when the short one finishes and see what happens.
It a disposable boot drive so no worries if it fails -- it's encouraging me to setup iscsi boot for this machine:)
Peter
Users browsing this forum: Google [Bot] and 29 guests
