| Use HDD Low Level Format to migrate a hard disk http://forum.hddguru.com/viewtopic.php?f=7&t=29334 |
Page 1 of 1 |
| Author: | loninappleton [ August 22nd, 2014, 12:51 ] |
| Post subject: | Use HDD Low Level Format to migrate a hard disk |
I had good success using a technique in Win XP which involved resetting the HD controller to 'default' from a drive specific one-- I can provide the link if needed. What this allowed was for a fully populated HD to be moved from one motherboard to another. That worked after re-running all the motherboard drivers on the target motherboard. Now I wanted to do something similar in Win 7: move nad wipe an HD from one motherboard and reinstall and load Win 7 on a different (Biostar MCP6PB M2+) motherboard. To that endI prepped the HD with HDD Guru Low Level Format. Unfortunately I still got the blue screen error which indicates that a HD has been moved from where the OS was installed. Why didn't the Low Level format routine give a clean slate for the OS install? And is there one sure fire way to wipe and prep for rei-nstallation to a different motherboard? |
