| WD3200BPVT-22z SATA drive password unlock or recovery http://forum.hddguru.com/viewtopic.php?f=7&t=29372 |
Page 1 of 1 |
| Author: | illwill [ August 27th, 2014, 17:24 ] |
| Post subject: | WD3200BPVT-22z SATA drive password unlock or recovery |
WD3200BPVT-22z sata drive has hdd password set on gateway laptop after trynig to figure out how to finally get scripts into the script directory and get a working image mhdd gives me “error: no drq” when running any of the scripts (.dump,.dump2,etc..) trying to use zu.exe doesnt work after a few hours , put it in a pentium 4 machine also no go even tried victoria hdd tool on hirens to unlock also default WDCWDCWDCWDC and h2oinsyde password not working i would like to see what password was set , any other way to dump the bin? |
| Author: | illwill [ September 3rd, 2014, 18:43 ] |
| Post subject: | Re: WD3200BPVT-22z SATA drive password unlock or recovery |
anyone? |
| Author: | lcoughey [ September 4th, 2014, 8:06 ] |
Ask the owner for the password. |
| Author: | illwill [ September 4th, 2014, 20:52 ] |
Thanks Captain Obvious. |
| Author: | loki [ September 7th, 2014, 9:37 ] |
If you can prove ownership? just take or send it to a DR Pro who has the tools & knowledge to do this for a fee. is the data important? if not & you want to try DIY then you will need to do a lot of researching. Members on this forum cannot prove you are the owner of the hdd drive & helping you to bypass the password could end them in a lot of trouble if the drive turns out to be stolen. Please note I am not saying that it is so no offence is meant. Loki |
| Author: | illwill [ September 16th, 2014, 15:43 ] |
I should have mentioned in first post , this is not my computer, I do pc repair and it is for a customer of mine. I'd just assume pull the drive and install a new one and reinstall windows, I figured Id help the guy not incur the cost of doing so. |
| Author: | hhddrec [ September 16th, 2014, 17:14 ] |
if data is not significant, exchange drive and reinstal o.s. because as said here we can not verify owner good look |
