| HDD new? SMART Power Off Retract Count and Load Cycle Count http://forum.hddguru.com/viewtopic.php?f=7&t=29551 |
Page 1 of 1 |
| Author: | BlueDragon [ September 17th, 2014, 11:43 ] |
| Post subject: | HDD new? SMART Power Off Retract Count and Load Cycle Count |
Hi, I just received my new (?) HDD in an open antistatic bag with following SMART attributes: Code: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 100 253 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 100 253 021 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 3 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 100 253 000 Old_age Always - 0 9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 0 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 3 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 1 193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 1 194 Temperature_Celsius 0x0022 117 117 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 100 253 000 Old_age Offline - 0 I'm a bit puzzled about the interpretation of these values... I understand the spindle has started to rotate 3 times (SMART attribute #4) which is in line with the power cycle count of 3 (SMART attribute #12). Now what about this 'Power Off Retract Count' (SMART attribute #192) and the 'Load Cycle Count' (SMART attribute # 193) of both being only 1? Goggling around I found many quite contradictory explanations about these 2 latter attributes... #192: Wikipedia: "Count of times the heads are loaded off the media. Heads can be unloaded without actually powering off." HD Sentinel: "Count of power off cycles" Both these information are logically not fitting together. And in this SMART example above clearly the the drive has been powered up/down 3 times but power off retract count is only 1. How can that be? #193: Wikipedia: "Count of load/unload cycles into head landing zone position." HD Sentinel: "Count of load/unload cycles" How can the drive in this example above has been power cycled 3 times and the head unloaded only 1 time?? In any case this HDD is not totally new, since it has been power cycled at least 2 times before I connected it. Not a big problem at all I guess but still a bit unpleasant given the fact that the manufacturing date is Jan 2014 and I just received it today. Like I'm used to do I will start a surface scan before I will fill it with data. BTW what would you guys advise to check / test basically before starting to use a new (?) drive? Simple surface read scan or filling it with zeros or more? Thanks for your answers! |
