| WD 2TB LL format http://forum.hddguru.com/viewtopic.php?f=7&t=29574 |
Page 1 of 1 |
| Author: | larrylwill [ September 21st, 2014, 16:32 ] |
| Post subject: | WD 2TB LL format |
I dropped a WD 2 TB green hard drive and now it has a lot of bad sectors, I was able to recover all the files off it and wanted to lock out the bad sectors, so I tried several disk checking programs to fix or lock them, Windows chkdsk, paragon, eseus, mini tool. All got so far then stopped. I was able to creat and make a 200mb partition and format it and check it. So I decided to start over with a ll format and found HDD LL format and started it but it was slow, so I purchased it and now its running but I can not get any reading of the speed. Its been running 20 minuets and its only one 87,000 sectors, but the speed mbs = 0, I did see it jump to 0.1 once. I am connected directly to the mother board on a amd 8 core 3.1ghz cpu with 4gb of ram. From reading this forum I should get several hundred MB's speed. Any idea why mine is so slow? I have rebooted and disabled every unessential program. |
| Author: | labtech [ September 21st, 2014, 16:57 ] |
| Post subject: | Re: WD 2TB LL format |
The drive's firmware may have been affected by the accumulation of bad sectors. Also, there is a possibility the mechanics are weak. Seel it for parts. Once dropped, likely no longer reliable. |
| Author: | Dmitri [ September 21st, 2014, 17:06 ] |
| Post subject: | Dropped WD 2TB, LL format |
larrylwill wrote: I dropped a WD 2 TB green hard drive ... I was able to recover all the files off it If that was a real drop and not a few centimeters, then you're a lucky person. Now you have a hi-tech door stopper, keep it as your lucky mascot. I doubt anyone here will recommend you to re-use the drive somehow else. |
| Author: | fzabkar [ September 21st, 2014, 17:18 ] |
I wouldn't use that drive for storage, but it might make a useful subject for study. I would begin by reading the "ROM" and firmware modules (SA): http://sediv2008.narod.ru/Easy3.9Passwo ... 567890.rar MOD 34 is the G-list and MOD 32 is the relo-list. These should tell us which head(s) were damaged. |
| Author: | larrylwill [ September 21st, 2014, 17:43 ] |
What is that program ? What is the name of it? I can open and extract. I ran it in a sandbox but get an error. DIV has stopped working. |
| Author: | fzabkar [ September 21st, 2014, 20:10 ] |
http://sediv2008.narod.ru/Settings.rar http://sediv2008.narod.ru/ |
| Author: | larrylwill [ September 22nd, 2014, 18:29 ] |
DIV Has stopped working Here is the log. I also checked for an online solution and got another error message. Exception EOlesSysError in module SeDiv.exe at 000E2941. Invalade window handel. Im running Win 7 Problem signature: Problem Event Name: APPCRASH Application Name: SeDiv.exe Application Version: 3.9.7.5 Application Timestamp: 2a425e19 Fault Module Name: KERNELBASE.dll Fault Module Version: 6.1.7601.18409 Fault Module Timestamp: 53159a86 Exception Code: 0eedfade Exception Offset: 0000c42d OS Version: 6.1.7601.2.1.0.256.1 Locale ID: 1033 Additional Information 1: 5ac6 Additional Information 2: 5ac69eafdcbbf60109f54d765e15a79f Additional Information 3: e41a Additional Information 4: e41a2d7812f2206bc6f17352c9ac95e8 Read our privacy statement online: http://go.microsoft.com/fwlink/?linkid= ... cid=0x0409 If the online privacy statement is not available, please read our privacy statement offline: C:\Windows\system32\en-US\erofflps.txt |
| Author: | larrylwill [ September 22nd, 2014, 18:30 ] |
I sent a reply but got the message it has to be approved by a moderator for some reason. I included the error message DVI has stopped working and the log that I got. |
| Author: | fzabkar [ September 22nd, 2014, 18:44 ] |
Use Windows XP instead, if you have it. |
| Author: | larrylwill [ September 22nd, 2014, 19:17 ] |
I tried it in compatibility mode, still wont run, I have a computer on a piece of equipment with a copy of ME on it I will try later. |
