 Post subject: SATA Port Selectors
PostPosted: November 20th, 2014, 8:33
Has anyone experimented with SATA Port Selectors?
I wonder if it would work for connecting one hard drive to two data recovery tools, such as a firmware tool and an imaging tool at the same time. This would minimise the risk due to having to power down a drive and move it between tools; sometimes drives only come ready once.
 Post subject: Re: SATA Port Selectors
PostPosted: November 20th, 2014, 9:27
If you supply power to the drive from your data extraction/imaging tool, but connect the drive's sata cable to the firmware tool, once you fix the firmware issue, switch the drive's sata cable to the imager and proceed with imaging/data extraction.
PostPosted: November 20th, 2014, 14:15
Or just buy PC-3000 with Data Extractor, and you'll never have to do any cable swapping.
PostPosted: November 21st, 2014, 5:23
Thanks guys, I predicted both those responses :)
Users browsing this forum: No registered users and 35 guests
