| SATA Port Selectors http://forum.hddguru.com/viewtopic.php?f=7&t=29990 |
Page 1 of 1 |
| Author: | Cris [ November 20th, 2014, 8:33 ] |
| Post subject: | SATA Port Selectors |
Has anyone experimented with SATA Port Selectors? I wonder if it would work for connecting one hard drive to two data recovery tools, such as a firmware tool and an imaging tool at the same time. This would minimise the risk due to having to power down a drive and move it between tools; sometimes drives only come ready once. |
| Author: | LarrySabo [ November 20th, 2014, 9:27 ] |
| Post subject: | Re: SATA Port Selectors |
If you supply power to the drive from your data extraction/imaging tool, but connect the drive's sata cable to the firmware tool, once you fix the firmware issue, switch the drive's sata cable to the imager and proceed with imaging/data extraction. |
| Author: | data-medics [ November 20th, 2014, 14:15 ] |
Or just buy PC-3000 with Data Extractor, and you'll never have to do any cable swapping. |
| Author: | Cris [ November 21st, 2014, 5:23 ] |
Thanks guys, I predicted both those responses |
