 Post subject: Cloning and resizing partitions software
PostPosted: December 12th, 2014, 6:14
Hi
I am having some trouble cloning drives (I have a job to replace mechanic drives for SSD on several PC's).
I need that the software also resize the partitions.
I have tried Drive Clone and Easeus TODO backup, but the clones faill to boot.
Do you guys have another ideas that work?
ACELab partner
 Post subject: Re: Cloning and resizing partitions software
PostPosted: December 12th, 2014, 6:49
Have a look at "R-Drive Image", you can trial it for 30 days:
http://www.drive-image.com/
and it is made by the same company as R-Studio.
PostPosted: December 12th, 2014, 8:02
Hi Cris
Thanks for the sugestion, but R-Image can't resize....
ACELab partner
PostPosted: December 12th, 2014, 9:21
I generally use Paragon hard disk manager in our shop. Great support specific to shrinking data to transfer to SSD's included.
PostPosted: December 12th, 2014, 9:25
I use Paragon Migrate Disk to SSD for that and it works great. Tried many other programs with little success. And it's very inexpensive.
PostPosted: December 12th, 2014, 10:36
Thanks Guys.
I will test those too.
You don't have problems with 4k alignments, to be windows 7 or windows 8?
ACELab partner
PostPosted: December 12th, 2014, 11:33
It handles Win7 and 8-8.1 fine. Don't know if it handles 4k segment disks but I would assume so. I just slave the customer's drive to my Win7 x86 PC and migrate to the customer's SSD using eSATA drive docks.
PostPosted: December 12th, 2014, 18:34
If clone fails to boot, did you check with something like diskpart that partition is active and also, in windows after I image with image.exe, I need to write the boot files with something like :
c:\Windows\System32\bcdboot c:\Windows
replace c: with the target drive... mine is typically D: during imaging, but reverts to c: once the system is up and running
http://technet.microsoft.com/en-au/library/dd744531(v=ws.10).aspx
PostPosted: December 13th, 2014, 11:41
copying 4k to 4k no problem: only. Must be same.
PostPosted: December 14th, 2014, 19:04
ISTM that most SSD manufacturers have free data migration software.
Samsung Data Migration Software:
http://www.samsung.com/global/business/ ... per11.html
Intel Data Migration Software:
https://downloadcenter.intel.com/Detail ... ldID=19324
SanDisk SSD Conversion Kit:
http://www.sandisk.com.au/products/ssd/ ... rsion-kit/
"The SanDisk SSD Conversion Kit also comes with convenient data-migration software ..."
PostPosted: December 14th, 2014, 19:43
Do any of these migration tools work without problems when working with Linux, say Ubuntu OS, for example?
PostPosted: December 15th, 2014, 3:50
try with Symantec Ghost
PostPosted: December 15th, 2014, 5:43
pclab wrote:
Hi Cris
R-Drive Image can. So can the Drive Copy wizard in R-Studio.
R-Studio Data Recovery Software
PostPosted: December 15th, 2014, 10:05
Alt(R-TT) wrote:
pclab wrote:
Hi Cris
I will test again.
ACELab partner
PostPosted: December 16th, 2014, 9:14
Damn, there are things that take out from serious....
I'm now trying a PC from the same client.
Againm tested with Drive Clone (cloned but can't boot), Drive Image says that it can copy, Easeus TODO backup clone, but can't boot... Paragon SSD says it can«t support OS :shock:
I have tried using a USB cady for destination and doing the clone on my PC (with a "master" and "slave" <SATA doesn't have this but for understanding>).
Now I'm using the client's PC with the SSD connected directly and doing the clone using the "original" OS.
It should be a damn simple thing and it's getting me MAD....
ACELab partner
PostPosted: December 16th, 2014, 10:09
why don't you resize the partitions down to small enough first, and once the partition will fit on the SSD, clone the partition only, then make sure it is bootable.
problem might be the condition the file system is in, will not resize down.
Don't really have enough info though, this looks like a job that you just "play with" until you find something that works
PostPosted: December 16th, 2014, 11:34
What is the OS? 32/64-bit? Tried with Secure Boot disabled?
PostPosted: December 16th, 2014, 13:49
Hi
So, my last option was to clone on the client's PC to the SSD attached with Easeus TODO.
And it worked...
Weird....
ACELab partner
PostPosted: December 16th, 2014, 14:03
+1 to Paragon SSD Migration tool.
It's become my go to software for this purpose and I've never had it fail me yet.
PostPosted: December 18th, 2014, 8:00
Hi
Use acronis true image
You basically install it on machine you are migrating drive on or create a bootable cd
Create image file to external drive
Replace drive on machine
Boot machine from cd acronis media
Apply image to new drive, you will have option to rest partition size
Works every time
Good luck
