 Post subject: Clone / Imaging : Bad Sectored USB Hard Drive
PostPosted: January 16th, 2015, 9:08
Hello Folks ,
We Get Lot Of USB Interface Based Drives .Though We Can Convert Then To SATA And Use Them Or Go For a SATA Compatiable PCB And Swap U12 ROM .I Would Be Interested In a Software That Can Do That Might Be In Non Windows Environment As Windows Environment Can Hang The system With This Kind Of Typical Issue .Any Suggestions Folks Please ....
PS : Each Of My Lab PC Has 2 Free PATA / SATA Ports If This Helps .
 Post subject: Re: Clone / Imaging : Bad Sectored USB Hard Drive
PostPosted: January 16th, 2015, 9:39
I just use DDI 4 with the USB add-on. Just mirrored one at 110MB/second (when not hitting read errors). There are many times when I cannot get PC3K to even recognize a USB drive...likely because windows is too busy interfering, but it detects and mirrors with DDI without any major issues.
PostPosted: January 16th, 2015, 12:08
You can consider the DFL-URE for such drives: http://www.dolphindatalab.com/dfl-ure-b ... -equipment
PostPosted: January 16th, 2015, 14:58
Media tools pro can clone USB devices, but falls over on hard error :-(
PostPosted: January 17th, 2015, 9:50
Luke And Larry ,
Only Interested in a Software Solution not windows Based .Both You People Are Talking About Hardware/Software Complex
PostPosted: January 17th, 2015, 10:24
You are not going to find a S/W solution that soft/hard/power resets the drive when you come to bad sectors. Use ddrescue if you must stick to a S/W solution (You probably already use that.)
PostPosted: January 17th, 2015, 13:26
Well,
I Do Not Use That But I Am Also Researching On Many Linux Based Imagers/Cloners Out There Like The Following
1 : Parted Magic Etc Etc
Not All Drives With Bad Sectors Need a Hardware Restart .Before i Was Into This Agressively I Used To Do Quite Few Recoveries With MediaTools .How Much Does The DDI 4 Complex Cost BTW Folks .
PostPosted: February 19th, 2015, 18:33
it costs $3300. i emailed them recently.
PostPosted: March 12th, 2016, 4:33
viewtopic.php?f=24&t=27524
READ THIS TOPIC
PostPosted: March 12th, 2016, 14:55
galaxy wrote:
http://forum.hddguru.com/viewtopic.php?f=24&t=27524
READ THIS TOPIC
Well,
If there is a tool that creates bugs and bugs with each update its dfl .I have all three dfl,mrt and pc3k .DDi4 X 2 NOS in the agenda
Users browsing this forum: No registered users and 47 guests
