Seagate : How to backup firmware
http://forum.hddguru.com/viewtopic.php?f=7&t=30438
Author:  samsam [ January 27th, 2015, 6:01 ]
Post subject:  Seagate : How to backup firmware
i'm newbie (sorry)
I receive my usb to ttl adapter
I plug, with various HDD and all is ok
Now I want to backup my original firmware before try to play with it.
I attemp with sediv (free version) but when i want to read I have the message 'only full version'
If I have understand, the firmware is composed by 3 part:
1 in rom, and 2 in hdd track (no direct access track "-41").
when i attemp to do lot of command , I have :
"INVALID Cert Disk Code - ROM resident revision required APN140"
if i understand, i need to put an cert in rom (or on track ?) before send order to read firmware ?
thanks for your help
ps: Test Disk information
Barracuda 7200.ES
GALAXY3D
firm :3.APPZ
serial: 9QG84TZN
on boot disk say me :
Reset
4096k x 32 DRAM
GALAXY - 1_Disk S-6D 02-02-07_11:01
on ^L :
2>GALAXY3D - 3_Disk 3.APPZ 12-03-07_17:44 APN,GX_3D_6H_S,14
Built for GALAXY3D,PITKIN,Redback,TI1843 PreAmp,Agere7539 PreAmp,McKinleyDT,3Disk,220 Servos,7200RPM,8Pole,133MHz,RwFeat=0002,VBAR
Author:  samsam [ January 27th, 2015, 6:57 ]
Post subject:  Re: Seagate : How to backup firmware
this hdd work fine
i don't think there is a damaged cert track but it's possible it was an IBM remanufactured seagate.
For the paid version software, I read that lot of soft allow to read the firmware but we need to pay to write it, correct ?
stcom is ok, but my version is not translated , (i use screeshot to know witch button to press).
I think all my hdd is older than F3 arch.
In my mind,i want to bkp all firm that I found and upload to this site, but if my bkp is corrupt, how can I detect it since I can't write it back to hdd ?
Author:  samsam [ January 27th, 2015, 9:03 ]
ok for the cert , I d'ont know it's possite sata work with cert damaged , thanks for sharing this information !
for the cert: it's writting on track ? where can I find the address to attempt to read ?
"loading firmware to RAM from F> and select the box to write to disk."
can you explain me more please ?
on stcom I use the "backup fw" and I check all the checkbox how can I verifiy my backup file are correct ?
there is a crc check tolls somewhere ?
thanks
Author:  samsam [ January 27th, 2015, 10:37 ]
I know your site , i'm member to ;-)
I go to search .
About basic understanding barracuda working, do you have doc/datasheet/info somewhere ?
thanks
Author:  samsam [ January 27th, 2015, 12:13 ]
PC3K UDMA english manuals have barracuda schematic block
but it's... in russian lol
thanks for the keyword, i go to google ;-)
Author:  samsam [ January 28th, 2015, 6:31 ]
If you want I will be happy to write this tutorial with you
