| Maxtor Firmware update - Help http://forum.hddguru.com/viewtopic.php?f=7&t=30683 |
Page 1 of 1 |
| Author: | adram [ March 8th, 2015, 5:15 ] |
| Post subject: | Maxtor Firmware update - Help |
Hi All, Can anyone give me some advice on what to do? I have a Maxtor STM31000528AS fireware CC38. It will power on but only remain accessible for about 5-10 minutes, then it goes off line. No usual sounds come from the drive. Spins up a normally and remains spun up. Figuring it might be a HDD Circuit board problem, I managed to find exactly the same drive (Maxtor STM31000528AS) except this had firmware CC35. I have swapped over the circuit boards but they don't work. Sorry, now for the questions? - If I upgrade the firmware on the new drive from CC35 to CC38, will the circuit board then work on the old drive so I can recover the files? - Or can I copy from the old drive (CC38) to the new drive (CC35) the firmware and settings?, would the new board work on the old drive? - What software should I use to do this? Any help would be greatly appreciated, the drive came out of my Wife's computer, which she hasn't done backups for a long time. Thank you. Adram |
| Author: | pcimage [ March 8th, 2015, 5:21 ] |
| Post subject: | Re: Maxtor Firmware update - Help |
Very much doubt it's a FW or PCB issue. Most likely bad sectors. |
| Author: | dick [ March 8th, 2015, 6:06 ] |
Adram. Your drive is failing and would need to be cloned to a replacement. You might be lucky and be able to copy your important files and folders using recovery software. In either case it would be a good idea to remove the drive from the system and position an external fan to blow cool air towards the drive while cloning or copying the data. Lowering the drive temp can often help keep it on line! IF THE DATA IS REALLY IMPORTANT TO YOU THEN GIVE IT TO A PRO WHO WILL DO IT FOR YOU FOR A RESONABLE CHARGE. pcimage who posted here could do that for you so make direct contact with him. Good luck! |
