 Post subject: change sector size of SAS hard disk !!
PostPosted: April 28th, 2015, 23:14
Hello !!
I want to know , how to change SAS hard disk's sector size ?????
From 520 Byte to 512 Byte and vice versa .
Is there a way to do this ?????
I want to change sector size of Hitachi and Seagate SAS hard disk !!!!
Thanks for your help !!!!
 Post subject: Re: change sector size of SAS hard disk !!
PostPosted: April 29th, 2015, 3:19
Maybe this?
http://linux.die.net/man/8/sg_format
PostPosted: April 29th, 2015, 11:40
thanks !!
I try this command but did not work !!!
Do you know another way ????
PostPosted: April 29th, 2015, 11:48
thanks !!
but this command did not work correctly !!
do you know another way ????
PostPosted: April 29th, 2015, 14:52
It's possible that some firmware versions have a hard coded sector size of 520 and refuse the setting.
What OEM & FW are they?
PostPosted: April 30th, 2015, 6:56
Try the enterprise version of SeaTools.
The following URLs are old, but you should be able to find something more current:
http://forums.storagereview.com/index.p ... 0-sectors/
ftp://ftp.psu.ac.th/pub/seagate/sthelp.txt
If using Seagate's Linux tool ...
    st -B 520 /dev/ice
PostPosted: April 30th, 2015, 10:18
hello
If i change the sector size from 520 bytes to 512 bytes , can i change it to 520 bytes again ???
PostPosted: April 30th, 2015, 12:28
Of course
PostPosted: May 6th, 2015, 22:13
thanks !! but these ways did not useful !!!
i could not change the sector size !!!!!!!
do you know any offer ?
PostPosted: May 8th, 2015, 2:41
PostPosted: May 8th, 2015, 2:52
Post logs and/or screen shots of the failure.
Users browsing this forum: No registered users and 127 guests
