Page 1 of 1
change sector size of SAS hard disk !!
Posted: April 28th, 2015, 23:14
by Albert94
Hello !!
I want to know , how to change SAS hard disk's sector size ?????
From 520 Byte to 512 Byte and vice versa .
Is there a way to do this ?????
I want to change sector size of Hitachi and Seagate SAS hard disk !!!!
Thanks for your help !!!!
Re: change sector size of SAS hard disk !!
Posted: April 29th, 2015, 3:19
by fzabkar
Posted: April 29th, 2015, 11:40
by Albert94
thanks !!
I try this command but did not work !!!
Do you know another way ????
Posted: April 29th, 2015, 11:48
by Albert94
thanks !!
but this command did not work correctly !!
do you know another way ????
Posted: April 29th, 2015, 14:52
by guru
It's possible that some firmware versions have a hard coded sector size of 520 and refuse the setting.
What OEM & FW are they?
Posted: April 30th, 2015, 6:56
by fzabkar
Try the enterprise version of SeaTools.
The following URLs are old, but you should be able to find something more current:
http://forums.storagereview.com/index.p ... 0-sectors/ftp://ftp.psu.ac.th/pub/seagate/sthelp.txtftp://ftp.psu.ac.th/pub/seagate/stIf using Seagate's Linux tool ...
Posted: April 30th, 2015, 10:18
by Albert94
hello
If i change the sector size from 520 bytes to 512 bytes , can i change it to 520 bytes again ???
Posted: April 30th, 2015, 12:28
by guru
Of course
Posted: May 6th, 2015, 22:13
by Albert94
thanks !! but these ways did not useful !!!
i could not change the sector size !!!!!!!
do you know any offer ?
Posted: May 8th, 2015, 2:41
by Albert94
Posted: May 8th, 2015, 2:52
by guru
Post logs and/or screen shots of the failure.
