 Post subject: wd Sata ATA lock how to unlock
PostPosted: May 12th, 2015, 8:28
hi
it appears my oem wd drive has a ata lock on it when i try to use it in another pc
how do i remove the lock?
cant find any info online
 Post subject: Re: wd Sata ATA lock how to unlock
PostPosted: May 12th, 2015, 8:47
WOW
the longest thread here on the forum about 50 pages long and you cant find any ?
PostPosted: May 12th, 2015, 16:23
Spildit wrote:
The easy way is by the use of WDR Demo (free) assuming your drive doesn't lock SA access when ATA password is present.
If SA access is locked you can try ZU otherwise you will need to hot swap or swap ROM/PCB in a way it will not have the same version as perm overlay so SA is not loaded, etc...
ok i tried to use the WDR Demo software
it appears every function says "PRIVILIGED Instruction" when i test it
Im not sure what im supposed to use to unlock this wd drive
it shows wd-marvel and wd-royal and soft reset
I have a scorpio blue
can you give me some instruction
yes the drive works fine in my origional sata port on the pc it came with. if i unlock it in the oem pc i could probably use it on the other pc
PostPosted: May 13th, 2015, 8:52
thanks for the info
I tried WDR demo but all functions seem to say "PRIVILEGED Instruction"
what function is unlock? I don't see any unlock feature?
Maybe you can give me a little instruction.
thanks
PostPosted: May 14th, 2015, 7:37
Drive model?...
PostPosted: May 14th, 2015, 8:47
Suitsof wrote:
Drive model?...
wd scorpio 7500bpvt
PostPosted: May 14th, 2015, 13:53
Try this http://wdmarvel.com/en/
Do you have some special equipment (PC3K, HRT, Atola etc.)?
PostPosted: May 14th, 2015, 17:43
Spildit wrote:
WDR DEMO requires 32 bit windows because of driver installation :
PRIVILIGED Instruction is caused either by the fact that the driver didn't install properly or because you are not running with admin priviledges.
Try again, if it fails you can try the MHDD script to read password module or use alternative tools like WDMarvell or SeDiv.
Well i put a 32 bit windows on the drive and ran the wdr demo again
your right, it will run in 32bit windows - no errors or privilege errors showing now
the problem is the drive does not seem to be reading. I tried to use the marvel and royl menus to edit password but it does not read nothing from the drive. it appears nothing on the drive is being identify on this WDR DEMO program either.
PostPosted: May 14th, 2015, 17:47
no, I dont have special equipment.
I tried the wdmarvel software. I get errors when I try to clear the password in either marvel
here is the log
5/14/2015 2:30:37 PM: Controllers search, found 2 devices
5/14/2015 2:30:37 PM: Device selected 3088h 3096h Master
5/14/2015 2:30:37 PM: Network error while communicating with the server.
5/14/2015 2:31:44 PM: Error when restart the FW
5/14/2015 2:32:44 PM: Error reading Config
the sediv program just crashes on 32 and 64 bit windows, i cant run it
says kernal error crash
PostPosted: May 15th, 2015, 8:29
Spildit wrote:
hddtalk wrote:
Spildit wrote:
Did you select the correct PORT where the drive is connected ?
Do you have the drive directly connected by SATA instead of USB adaptor ?
Just connect the drive by SATA, using WDR go to Options - Port - Custom and select the port where the drive is connected first, you should see drive ID on the RIYL window.
yes I tried master slave and custom
I dont think I have the port selected correctly. How do I identify the correct port.
I just used the custom default
i get this on the log showing its not detecting it
FW: SN: (ROYL selected) port 0x170
Logical: Cyls 0, Heads 0, Sectors 0, LBA 0, 0Gb
Controller Buffer Size: 0Kb
Family: Unknown
Family: Unknown
PostPosted: May 15th, 2015, 19:52
Spildit wrote:
Chose custom and you should see a list of ports. If you don't see the list then the driver is not correctly installed. If you see a list of custom ports select one by one and open the royl utility untill you see the correct drive.
yes, I dont see a list of ports
only see one port in the text box by default
PostPosted: May 16th, 2015, 20:52
[/img]
yes i tried those options win xp 32bit
I still do not get any listings in the custom menu
