| Cannot Open Access 2007 MDB file http://forum.hddguru.com/viewtopic.php?f=7&t=31641 |
Page 1 of 1 |
| Author: | laynehoover [ July 23rd, 2015, 13:21 ] |
| Post subject: | Cannot Open Access 2007 MDB file |
I have an Access 2007 file that I was working on at my office. I left for the day and the database was still open. When I came back the next day the system had shut off so I rebooted (no issues). I tried to open the database and am getting the error message: "Unrecognized database format 'C:\....\filename.mdb" I cannot get into the file, I cannot Compact/Repair it either. Anyone have any suggestion on how to get the data "out" I have tried using Access External Data, Creating an new DB and importing the broken file but I cannot get past the error message. I can open previous versions of the same database. I really need to get the data. I can attached the file if someone can figure out what to do with it?? |
| Author: | pcimage [ July 23rd, 2015, 17:23 ] |
| Post subject: | Re: Cannot Open Access 2007 MDB file |
Firstly, check the size of the file to see if it's the expected size, then try this... http://www.officerecovery.com |
| Author: | Mathew [ August 10th, 2015, 13:01 ] |
pcimage wrote: Firstly, check the size of the file to see if it's the expected size, then try this... http://www.officerecovery.com I have the same problem, but the software you say is very bad, it can only recover tables. Can you recommend me other software like this, but more powerful? |
| Author: | data-medics [ August 10th, 2015, 15:38 ] |
You can try the one from Stellar. They are a spammy company I don't personally care for, but the software claims to be able to do more than just the tables. |
| Author: | Mathew [ August 12th, 2015, 10:08 ] |
Maybe, in my case the task of the software was very poor. Stellar software works better, I could recover many fields, however I need recover high precision numbers still. Is there a tool specific for recover high precision numbers in Access? or this is not possible. |
| Author: | chinopk [ August 12th, 2015, 11:41 ] |
upload file here in compress format |
| Author: | data-medics [ August 12th, 2015, 15:39 ] |
chinopk wrote: upload file here in compress format Ummm.... I don't think posting that sort of data to a publicly accessible forum is a very good idea. |
| Author: | chinopk [ August 13th, 2015, 4:48 ] |
data-medics wrote: chinopk wrote: upload file here in compress format Ummm.... I don't think posting that sort of data to a publicly accessible forum is a very good idea. agreed but OP already mentioned he can. |
