 Post subject: Outlook calendar entry corrupted. Constant pop up when you o
PostPosted: July 26th, 2015, 15:31
I have an outlook calendar entry that was created on the 28th November 2010 which constantly pops up when i open outlook. When you click Dismiss or Dismiss All, you receive a message advising the entry is corrupted.
Any ideas?
Thanks.
 Post subject: Re: Outlook calendar entry corrupted. Constant pop up when y
PostPosted: July 26th, 2015, 20:43
you might try looking for an outlook fix tool. IIRC there was one built into office.
I am not sure why you chose a hard drive forum instead of a windows forum, as usually if you direct your query to the appropriate place you get better results.
you don't say what you have already tried, if anything, but google pulled up this:
Calendar Checking Tool for Outlook - Version 2.4
http://www.microsoft.com/en-au/download/details.aspx?id=28786
PostPosted: July 26th, 2015, 22:25
And ensure you make a couple of file copies before applying the fix.
PostPosted: July 26th, 2015, 22:29
a very strong +1 for that advice :)
Users browsing this forum: No registered users and 29 guests
