 Post subject: recovery of overwritten records from dvr
PostPosted: July 31st, 2015, 10:19
Dear All,
I am facing an issue and i am seeking your support on the following...
i have a DVR-HDD (1TB), in which the date 24.6.2015 records starts from 5pm and it ends on 15.7.2015
Now i need records of 24.6.2015 from 10AM to 5pm.
Is it possible to recover overwritten data
 Post subject: Re: recovery of overwritten records from dvr
PostPosted: August 1st, 2015, 15:37
Overwritten data is impossible to recover.
ACELab partner
 Post subject: recover overwritten recordings from dvr
PostPosted: August 2nd, 2015, 13:01
intech wrote:
i have a DVR HDD (1TB), in which the date 24.6.2015 records starts from 5pm and it ends on 15.7.2015
How did you find out the available dates range? If the drive and the unit itself are OK and you checked that using some internal means, then not much can be done, unfortunately.
DVR recordings are looped and the oldest ones are getting overwritten once the drive is full.
According to our experience with DVRs, it could be possible to recover an extra 1%, which may appear gone due to a different algorithm imperfections.
In rare cases this number can go up to 2, maybe 3%, as some models add gaps between groups of frames and something can be there, but that's more of a luck than technology.
Users browsing this forum: No registered users and 38 guests
