recovery of overwritten records from dvr
http://forum.hddguru.com/viewtopic.php?f=7&t=31693
Author:  intech [ July 31st, 2015, 10:19 ]
Post subject:  recovery of overwritten records from dvr
Dear All,
I am facing an issue and i am seeking your support on the following...
i have a DVR-HDD (1TB), in which the date 24.6.2015 records starts from 5pm and it ends on 15.7.2015
Now i need records of 24.6.2015 from 10AM to 5pm.
Is it possible to recover overwritten data
Author:  pclab [ August 1st, 2015, 15:37 ]
Post subject:  Re: recovery of overwritten records from dvr
Overwritten data is impossible to recover.
Author:  Dmitri [ August 2nd, 2015, 13:01 ]
Post subject:  recover overwritten recordings from dvr
intech wrote:
i have a DVR HDD (1TB), in which the date 24.6.2015 records starts from 5pm and it ends on 15.7.2015
How did you find out the available dates range? If the drive and the unit itself are OK and you checked that using some internal means, then not much can be done, unfortunately.
DVR recordings are looped and the oldest ones are getting overwritten once the drive is full.
According to our experience with DVRs, it could be possible to recover an extra 1%, which may appear gone due to a different algorithm imperfections.
In rare cases this number can go up to 2, maybe 3%, as some models add gaps between groups of frames and something can be there, but that's more of a luck than technology.
