 Post subject: Force run the FW upgrade iso file: How to decode
PostPosted: August 27th, 2015, 19:38
How Can we decode the ST31500341AS upgarde ISO file to force the bios upgrade. The file in question is Brinks-4D8H-CC1H.iso. Could not attach is as there is some restriction. But the same can be downloaded from
http://blog.salty.uk.com/post/Seagate-H ... grade.aspx
 Post subject: Re: Force run the FW upgrade iso file: How to decode
PostPosted: August 27th, 2015, 20:16
If this is applicable to your drive, then start by extracting all the files.
1) Install 7-Zip
2) Right click the zipfile ST31500341AS_CC1H.zip and choose 7-Zip/extract to ST31500341AS_CC1H
3) Go into ST31500341AS_CC1H and right-click Brinks-4D8H-CC1H.ISO and choose 7-Zip/extract to Brinks-4D8H-CC1H
4) Go into Brinks-4D8H-CC1H then [BOOT], right-cligh Bootable_1.44M.img and choose 7-Zip/extract to Bootable_1.44M
5) Go into Bootable_1.44M and right-click 15TBCC1H.ZIP and choose 7-Zip/extract to 15TBCC1H
your firmware is the 8hCC1h.lod file
read through all the .txt, .bat files etc and see what the next steps are, and if it applies to your drive.
sometimes there is a reason your disk rejects an update
backing up files should be your first step of course before mucking around with firmware
PostPosted: August 27th, 2015, 20:45
The updater does not check your existing firmware for compatibility, so there is no need to force anything. That said, you must not apply the CCxx update over incompatible firmware.
WARNING: Do NOT use on any drive with SDxx firmware!!!!
You will brick your drive if you do the above. I have witnessed it. Also, do not apply this retail update to OEM firmware, eg Dell, HP, etc.
PostPosted: August 27th, 2015, 20:59
Oh, Fzabkar,
such a quick response.
Actually i was asking for the command like
c:\> FDL??? -m ????? -f *.lod -s -x -b -v -s 20 command at C prompt
after control-break in case of the above iso.
Would u please download from the above and provide me the command pleaseeeeee.........
Thank you in advance.
PostPosted: August 27th, 2015, 21:38
The flash.bat file has the following lines:
set exe=fdl457.exe
set model=
set family=Brinks
set firmware=8HCC1H.lod
set options=-s -x -b -v -a 10
set model=ST31500341AS
%exe% -m %family% -f %firmware% -i %model% %options%
The resulting command line is ...
    fdl457 -m Brinks -f 8HCC1H.lod -i ST31500341AS -s -x -b -v -a 10
PostPosted: August 27th, 2015, 23:36
THANKS.....Dear
&& MANY MANY THANKS for the TUTORIAL........
PostPosted: August 28th, 2015, 1:33
remember.. backup if you need to first!
PostPosted: August 28th, 2015, 12:47
Now my story.
I booted from the CC1H CD and cntl+break to c:\>
Give the above command ..................mismatch shown expected ST31500341AS found MT_M13FQBL
Now iI in the command line changed ST31500341AS to MT_M13FQBL
This time the command executed BUT a big but nothing happened......
Following reflections came
Binary download
attempting to read binary file: 8HCC1H
Invalid data
Resetting Device
Model ST_M13FQBL NQNR_BFW FW117F38F
Exit with code 0
c:\>
Now how to write bios.
PostPosted: August 28th, 2015, 13:30
You have problem with original FW. You can not fix it with FW update.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: August 28th, 2015, 21:38
So EXPERTS, what is the way out here and actually what is CORRUPTED?
