BaseReplace V2 4TB Toshiba Template
http://forum.hddguru.com/viewtopic.php?f=7&t=32037
Author:  hddrepair-tech [ October 2nd, 2015, 13:55 ]
Post subject:  BaseReplace V2 4TB Toshiba Template
I have Just completed a perfect clone from a Jammed Spindle 4TB Toshiba Hard drive
Model: MD04ACA400
I used V2 of my BaseReplace Tool modifying two holes so that is would sit correctly
The heads were also removed prior to using the tool
I have attached a template that you can use as a guide to make this modification to your existing V2 Basereplace
Note
the spindle motor on the donor Base had a balancing plug that could not be seen until platters were removed
as the Original did not, I chose to remove it
File comment: Toshiba Template for BaseReplace V2
Toshiba BaseReplace Template.PDF [22.82 KiB]
Downloaded 696 times
