HDD GURU FORUMS
http://forum.hddguru.com/
Sediv new update For XP and windows 7
http://forum.hddguru.com/viewtopic.php?f=7&t=32102
Page 1 of 1
Author:  waqas_ali766 [ October 15th, 2015, 10:48 ]
Post subject:  Sediv new update For XP and windows 7
Hi
The newly release software of Sediv version 5085
Now sediv support Windows 7 and XP
The main features are
1. Added DVT ARCO
2. Add Manual ARCO with editing of ARCO test parameters
3.support ARCO from Script 28 module and from Sediv own loaded ARCO from firmware
4. Add option to Run B1 and B2 after ARCO (Selective)
5. Add prepare Flash and Start Calibrator ARCO 44
This function use to create empty rom which have empty adaptives and translator.
6. Add option Load LDR
7. Add all 19xx ARCO 44 and Other's
8. Firebird Head cut unlock
This is full video of complete refurbishment of a hdd with new manual ARCO.
From ARCO 44 to SF
Step by step guide
download link
http://www.mediafire.com/download/dcjy5 ... +Drive.zip
Waqas Ali
www.sediv.net
waqasali766@hotmail.com
Author:  michael chiklis [ October 15th, 2015, 18:19 ]
Post subject:  Re: Sediv new update For XP and windows 7
I have old Seagate + WD version of Sediv which works only for XP.
As i know, old Sediv is strongly restricted depending on hardware and software, if you change hardware or any important software it stops working.
Is this new version restricted as older one?
Can i use this new version on Windows 7 with my old license?
If possible to use new version on windows 7, would it get locked easily as older version if i install any driver or important software ?
Author:  waqas_ali766 [ October 16th, 2015, 10:11 ]
Hi
No you cannot use old xp license on windows 7.
You need to activate the software in windows 7 again.
Yes the protection is remain same.
you can install any software like skype, yahoo, antivirus, remote, victoria, hdd scan , only the software which cannot effect the hardware.
like if you install a wireless USB and install its software then sediv stop working. because a new hardware is detected in windows.
if this happened, then you can reinstall windows by ghost image which you make after sediv activation, and remove the wireless USB. sediv start running again.
Waqas Ali
http://www.phpbb.com/
