Page 2 of 2
Re: Recover access to my old PVR Hard Drive's contents
Posted: November 4th, 2015, 18:40
by Rollo
Good idea! I'll do a disk image and the rest after this headache passes from me!
HaQue wrote:
Rollo wrote:THanks Haque but your ideas are way beyond me! :D
seeing as you are in AU, maybe I could have a look or a look at the disk image.
BTW, make sure you don't muck around with the original - take a disk image that is saved on a different disk and work on the image. I can image it to a drive if you aren't confident.
Posted: November 4th, 2015, 18:42
by Rollo
I'll try to produce a SMART report as soon as my headache goes away.
thanks
Can you show us a SMART report? You could use a tool such as CrystalDiskInfo. This will tell us if the drive has physical problems.[/quote]
Posted: November 5th, 2015, 19:33
by Rollo
Rollo wrote:I'll try to produce a SMART report as soon as my headache goes away.
thanks
[/quote]
___________________________________________________________
Here is the log and screenshot from that run:
tests:
New - http://imgur.com/a/Q7gGG
Old - http://imgur.com/a/otgPj
REports:
CrystalDiskInfo 6.5.2 (C) 2008-2015 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Professional SP1 [6.1 Build 7601] (x64)
Date : 2015/11/05 16:03:52
-- Controller Map ----------------------------------------------------------
+ ATA Channel 1 (1) [ATA]
- ST500DM002-1BD142 ATA Device
+ Standard Dual Channel PCI IDE Controller [ATA]
- ATA Channel 0 (0)
+ ATA Channel 1 (1)
- ASUS DRW-24D3ST ATA Device
+ Standard AHCI 1.0 Serial ATA Controller [ATA]
- ATA Channel 1 (1)
-- Disk List ---------------------------------------------------------------
(1) ST500DM002-1BD142 : 500.1 GB [0/2/0, pd1] - st
(2) ST3500312CS : 500.1 GB [2/X/X, jm1] (V=152D, P=2338) - st
Model : ST500DM002-1BD142
Firmware : KC48
Serial Number : S2AS08MD
Disk Size : 500.1 GB (8.4/137.4/500.1/500.1)
Buffer Size : 16384 KB
Queue Depth : 32
# of Sectors : 976773168
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
Transfer Mode : SATA/600 | SATA/600
Power On Hours : 2374 hours
Power On Count : 4172 count
Temperature : 31 C (87 F)
Health Status : Good
Features : S.M.A.R.T., AAM, 48bit LBA, NCQ
APM Level : ----
AAM Level : D0D0h [ON]
-- S.M.A.R.T. --------------------------------------------------------------
ID Cur Wor Thr RawValues(6) Attribute Name
01 102 _99 __6 00000008CC80 Read Error Rate
03 100 _99 __0 000000000000 Spin-Up Time
04 _97 _97 _20 000000000DCB Start/Stop Count
05 100 100 _36 000000000000 Reallocated Sectors Count
07 _82 _60 _30 00000B53D83A Seek Error Rate
09 _98 _98 __0 000000000946 Power-On Hours
0A 100 100 _97 000000000000 Spin Retry Count
0C _96 _96 _20 00000000104C Power Cycle Count
B7 100 100 __0 000000000000 Vendor Specific
B8 100 100 _99 000000000000 End-to-End Error
BB _99 _99 __0 000000000001 Reported Uncorrectable Errors
BC 100 _99 __0 000000000022 Command Timeout
BD 100 100 __0 000000000000 High Fly Writes
BE _69 _53 _45 00001F1E001F Airflow Temperature
C2 _31 _47 __0 000B0000001F Temperature
C3 _49 _39 __0 00000008CC80 Hardware ECC recovered
C5 100 100 __0 000000000000 Current Pending Sector Count
C6 100 100 __0 000000000000 Uncorrectable Sector Count
C7 200 200 __0 000000000000 UltraDMA CRC Error Count
F0 100 253 __0 CB4C00000901 Head Flying Hours
F1 100 253 __0 0000857C6207 Total Host Writes
F2 100 253 __0 00008C65311D Total Host Reads
-- IDENTIFY_DEVICE ---------------------------------------------------------
0 1 2 3 4 5 6 7 8 9
000: 0C5A 3FFF C837 0010 0000 0000 003F 0000 0000 0000
010: 2020 2020 2020 2020 2020 2020 5332 4153 3038 4D44
020: 0000 8000 0004 4B43 3438 2020 2020 5354 3530 3044
030: 4D30 3032 2D31 4244 3134 3220 2020 2020 2020 2020
040: 2020 2020 2020 2020 2020 2020 2020 8010 0000 2F00
050: 4000 0200 0200 0007 3FFF 0010 003F FC10 00FB 0010
060: FFFF 0FFF 0000 0407 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 850E 0006 0048 0040
080: 01F0 0029 346B 7F61 4163 3468 BE41 4163 007F 0029
090: 0029 0000 FFFE 0000 D0D0 0000 0000 0000 0000 0000
100: 6030 3A38 0000 0000 0000 0000 6003 0000 5000 C500
110: 6DDC 134C 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0029 6030
130: 3A38 6030 3A38 2020 0002 0140 0100 5000 3C06 3C0A
140: 0000 003C 0000 0008 0000 0000 004F 0280 0000 0000
150: 0008 0000 0000 0000 0000 0000 0000 0000 3F00 99E0
160: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
170: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
180: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
190: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
200: 0000 0000 0000 0000 0000 0000 303F 0000 0000 4000
210: 0000 0000 0000 0000 0000 0000 0000 1C20 0000 0000
220: 0000 0000 1020 0000 0000 0000 0000 0000 0000 0000
230: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
240: 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 F8A5
-- SMART_READ_DATA ---------------------------------------------------------
+0 +1 +2 +3 +4 +5 +6 +7 +8 +9 +A +B +C +D +E +F
000: 0A 00 01 0F 00 66 63 80 CC 08 00 00 00 00 03 03
010: 00 64 63 00 00 00 00 00 00 00 04 32 00 61 61 CB
020: 0D 00 00 00 00 00 05 33 00 64 64 00 00 00 00 00
030: 00 00 07 0F 00 52 3C 3A D8 53 0B 00 00 00 09 32
040: 00 62 62 46 09 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 60 60 4C 10 00 00 00
060: 00 00 B7 32 00 64 64 00 00 00 00 00 00 00 B8 32
070: 00 64 64 00 00 00 00 00 00 00 BB 32 00 63 63 01
080: 00 00 00 00 00 00 BC 32 00 64 63 22 00 00 00 00
090: 00 00 BD 3A 00 64 64 00 00 00 00 00 00 00 BE 22
0A0: 00 45 35 1F 00 1E 1F 00 00 00 C2 22 00 1F 2F 1F
0B0: 00 00 00 0B 00 00 C3 1A 00 31 27 80 CC 08 00 00
0C0: 00 00 C5 12 00 64 64 00 00 00 00 00 00 00 C6 10
0D0: 00 64 64 00 00 00 00 00 00 00 C7 3E 00 C8 C8 00
0E0: 00 00 00 00 00 00 F0 00 00 64 FD 01 09 00 00 4C
0F0: CB 1A F1 00 00 64 FD 07 62 7C 85 00 00 00 F2 00
100: 00 64 FD 1D 31 65 8C 00 00 00 00 00 00 00 00 00
110: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 82 00 58 02 00 7B
170: 03 00 01 00 01 55 02 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 6B 6F FD 72 C8 07 00 00
1B0: 00 00 00 00 01 00 12 02 07 62 7C 85 26 8A 00 00
1C0: 1D 31 65 8C EC EE 06 00 00 00 00 00 0D 26 00 00
1D0: 00 00 00 00 00 00 00 00 1C 1D 00 00 16 00 02 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 35
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C1
-- SMART_READ_THRESHOLD ----------------------------------------------------
000: 01 00 01 06 00 00 00 00 00 00 00 00 00 00 03 00
010: 00 00 00 00 00 00 00 00 00 00 04 14 00 00 00 00
020: 00 00 00 00 00 00 05 24 00 00 00 00 00 00 00 00
030: 00 00 07 1E 00 00 00 00 00 00 00 00 00 00 09 00
040: 00 00 00 00 00 00 00 00 00 00 0A 61 00 00 00 00
050: 00 00 00 00 00 00 0C 14 00 00 00 00 00 00 00 00
060: 00 00 B7 00 00 00 00 00 00 00 00 00 00 00 B8 63
070: 00 00 00 00 00 00 00 00 00 00 BB 00 00 00 00 00
080: 00 00 00 00 00 00 BC 00 00 00 00 00 00 00 00 00
090: 00 00 BD 00 00 00 00 00 00 00 00 00 00 00 BE 2D
0A0: 00 00 00 00 00 00 00 00 00 00 C2 00 00 00 00 00
0B0: 00 00 00 00 00 00 C3 00 00 00 00 00 00 00 00 00
0C0: 00 00 C5 00 00 00 00 00 00 00 00 00 00 00 C6 00
0D0: 00 00 00 00 00 00 00 00 00 00 C7 00 00 00 00 00
0E0: 00 00 00 00 00 00 F0 00 00 00 00 00 00 00 00 00
0F0: 00 00 F1 00 00 00 00 00 00 00 00 00 00 00 F2 00
100: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 60
(2) ST3500312CS
Enclosure : ST350031 2CS USB Device (V=152D, P=2338, jm1) - st
Model : ST3500312CS
Firmware : SC13
Serial Number : 6VVHP5V5
Buffer Size : 8192 KB
Queue Depth : 32
Rotation Rate : 5900 RPM
Interface : USB (Serial ATA)
Transfer Mode : SATA/150 | SATA/300
Power On Hours : 12164 hours
Power On Count : 2280 count
Temperature : 33 C (91 F)
Health Status : Caution
Features : S.M.A.R.T., APM, 48bit LBA, NCQ
APM Level : C0C0h [ON]
AAM Level : ----
01 113 100 __6 00000AD4F36E Read Error Rate
03 100 100 __0 000000000000 Spin-Up Time
04 100 100 _20 000000000001 Start/Stop Count
05 100 100 _36 000000000004 Reallocated Sectors Count
07 100 253 _30 000000000000 Seek Error Rate
09 _87 _87 __0 000000002F84 Power-On Hours
0C _98 _98 _20 0000000008E8 Power Cycle Count
BB __1 __1 __0 0000000001ED Reported Uncorrectable Errors
BC 100 _99 __0 000500050006 Command Timeout
BD __1 __1 __0 0000000003CC High Fly Writes
BE _67 _64 _45 000021210021 Airflow Temperature
C2 _33 _40 __0 001A00000021 Temperature
C3 _44 _32 __0 00000AD4F36E Hardware ECC recovered
C5 100 100 __0 000000000006 Current Pending Sector Count
C6 100 100 __0 000000000006 Uncorrectable Sector Count
0 1 2 3 4 5 6 7 8 9
010: 2020 2020 2020 2020 2020 2020 3656 5648 5035 5635
020: 0000 4000 0004 5343 3133 2020 2020 5354 3335 3030
030: 3331 3243 5320 2020 2020 2020 2020 2020 2020 2020
060: FFFF 0FFF 0000 0007 0003 0078 0078 0078 0078 0000
070: 0000 0000 0000 0000 0000 001F 0506 0002 0048 0040
080: 01F0 0029 346B 7D69 4133 3469 BC09 4133 407F 0031
090: 0031 C0C0 FFFE 0000 FE00 1000 0000 0000 2710 0000
100: 6030 3A38 0000 0000 0000 0000 0000 0000 5000 C500
110: 4B21 54DC 0000 0000 0000 0000 0000 0000 0000 401E
120: 401C 0000 0000 0000 0000 0000 0000 0000 0021 6030
150: 0008 0000 0000 0000 0000 0000 0000 0000 4000 8000
200: 0000 0000 0000 0000 0000 0000 103B 0000 0000 0000
210: 0000 0000 0000 0000 0000 0000 0000 170C 0000 0000
220: 0000 0000 1010 0000 0000 0000 0000 0000 0000 0000
250: 0000 0000 0000 0000 0000 39A5
000: 0A 00 01 0F 00 71 64 6E F3 D4 0A 00 00 00 03 03
010: 00 64 64 00 00 00 00 00 00 00 04 32 00 64 64 01
020: 00 00 00 00 00 00 05 33 00 64 64 04 00 00 00 00
030: 00 00 07 0F 00 64 FD 00 00 00 00 00 00 00 09 32
040: 00 57 57 84 2F 00 00 00 00 00 0A 13 00 64 64 00
050: 00 00 00 00 00 00 0C 32 00 62 62 E8 08 00 00 00
060: 00 00 B8 32 00 64 64 00 00 00 00 00 00 00 BB 32
070: 00 01 01 ED 01 00 00 00 00 00 BC 32 00 64 63 06
080: 00 05 00 05 00 00 BD 3A 00 01 01 CC 03 00 00 00
090: 00 00 BE 22 00 43 40 21 00 21 21 00 00 00 C2 22
0A0: 00 21 28 21 00 00 00 1A 00 00 C3 1A 00 2C 20 6E
0B0: F3 D4 0A 00 00 00 C5 12 00 64 64 06 00 00 00 00
0C0: 00 00 C6 10 00 64 64 06 00 00 00 00 00 00 C7 3E
0D0: 00 C8 C8 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160: 00 00 00 00 00 00 00 00 00 00 00 00 79 02 00 73
170: 03 00 01 00 01 72 02 00 00 00 00 00 00 00 00 00
180: 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
1A0: 00 00 00 00 00 00 00 00 DC 2F 82 40 D4 27 00 00
1B0: 00 00 00 00 00 00 5E 01 E7 56 90 9F 83 01 00 00
1C0: 3D 1E 78 A1 D1 01 00 00 00 00 00 00 37 BB 95 01
1D0: 00 00 00 40 03 00 00 00 45 1F 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 91
060: 00 00 B8 63 00 00 00 00 00 00 00 00 00 00 BB 00
070: 00 00 00 00 00 00 00 00 00 00 BC 00 00 00 00 00
080: 00 00 00 00 00 00 BD 00 00 00 00 00 00 00 00 00
090: 00 00 BE 2D 00 00 00 00 00 00 00 00 00 00 C2 00
0A0: 00 00 00 00 00 00 00 00 00 00 C3 00 00 00 00 00
0B0: 00 00 00 00 00 00 C5 00 00 00 00 00 00 00 00 00
0C0: 00 00 C6 00 00 00 00 00 00 00 00 00 00 00 C7 00
0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 EA
Posted: November 5th, 2015, 19:37
by Rollo
HaQue wrote:I would not do that. take a disk image as your first priority. You should only do operations on the disk where you are sure you understand the process and probable outcome, not just hope :)
alternatively, get DMDE or Partition Find and mount. image each partition to another disk. each tool makes it easy to do this and both are free.
you are at risk of losing everything if something goes south
Here is the result of the run: I only ran it for about 7% of the entire disk and outputted one item which yielded an empty folder.
[devscan]
scan_dev=1:0:11:-1:0x0:512:976773168:"\\?\usbstor#disk&ven_st350031&prod_2cs&rev_#000000000000&0#{53f56307-b6bf-11d0-94f2-00a0c91efb8b}"
scan_range="0x0-0x7470c06000"
scan_ltrack=1.0:0x20:1.1:630:1373:0x8eb796dad2000
scan_ltrackorg=1.1:630:0x10:0x0:0x0:0x7470c06000:0x400000
scan_lbps=512
scan_state_sec="block:0x2000;inc:0x40000;first:0x20000;shift:0x20000;sec:0x36aa1000;set:0x0"
scan_modules=0x2
module_flags="5;0x3,0x3,0x3,0x3,0x3,"
module_states="5;0x0,0x0,0x0,0x0,0x0,"
expgrp="5;0x1,0x1,0x0,0x0,0x5,"
modselected=4
volselected=-3
volsortcol=3
extarr="94;xml,reg,png,pdf,exe,exe,msi,msi,chm,jpg,jpeg,jpe,jif,jfif,jfi,wav,gif,\
rtf,htm,html,7z,vdi,vmdk,mp3,avi,tif,tiff,ps,doc,doc,xls,xls,ppt,ppt,wmv,wma,asf,\
psd,aif,aiff,aifc,snd,iff,flac,mid,midi,arc,bz2,tbz2,tar,ogg,oga,ogv,cab,gz,tgz,\
rar,iso,docx,xlsx,pptx,ott,odt,otg,odg,otp,odp,ots,ods,otc,odc,oti,odi,otf,odf,oth,\
odm,apk,apk,jar,zip,zip,zipx,zipx,mkv,flv,mov,mov,mp4,mp4,dll,mui,cpl,ocx,"
[rawscan]
ftarr="62;xml,reg,png,pdf,exe-DOS,exe-Win,chm,jpeg,wav,gif,rtf,html,7z,vdi,vmdk,\
mp3,avi,tiff,ps,doc,wmv,psd,aiff,flac,midi,arc,bz2,tar,ogg,cab,gz,rar,iso,docx,ott,\
odt,otg,odg,otp,odp,ots,ods,otc,odc,oti,odi,otf,odf,oth,odm,apk,jar,zip,zip-null,\
mkv,flv,mov,mp4-mov,mp4,elf,dll,WinPE,"
[extfsscan]
volsnum=269
vol_0=1024:26104:4096:32768:6528:6528:256:0:32:0:1:2:3:1:0
vol_0_n=1
vol_1=1342177280:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_1_n=1
vol_2=1342205952:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_2_n=1
vol_3=1342238720:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_3_n=1
vol_4=1342271488:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_4_n=1
vol_5=1342300160:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_5_n=1
vol_6=1342328832:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_6_n=1
vol_7=1342361600:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_7_n=1
vol_8=1342406656:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_8_n=1
vol_9=1342427136:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_9_n=1
vol_10=1342455808:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_10_n=1
vol_11=1342488576:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_11_n=1
vol_12=1342525440:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_12_n=1
vol_13=1342554112:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_13_n=1
vol_14=1342578688:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_14_n=1
vol_15=1342611456:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_15_n=1
vol_16=1342648320:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_16_n=1
vol_17=1342672896:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_17_n=1
vol_18=1342705664:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_18_n=1
vol_19=1342738432:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_19_n=1
vol_20=1342787584:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_20_n=1
vol_21=1342824448:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_21_n=1
vol_22=1342849024:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_22_n=1
vol_23=1342885888:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_23_n=1
vol_24=1342918656:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_24_n=1
vol_25=1342947328:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_25_n=1
vol_26=1342980096:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_26_n=1
vol_27=1343008768:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_27_n=1
vol_28=1343053824:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_28_n=1
vol_29=1343078400:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_29_n=1
vol_30=1343107072:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_30_n=1
vol_31=1343135744:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_31_n=1
vol_32=1343176704:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_32_n=1
vol_33=1343201280:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_33_n=1
vol_34=1343234048:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_34_n=1
vol_35=1343266816:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_35_n=1
vol_36=1343299584:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_36_n=1
vol_37=1343328256:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_37_n=1
vol_38=1343361024:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_38_n=1
vol_39=1343385600:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_39_n=1
vol_40=1343426560:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_40_n=1
vol_41=1343455232:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_41_n=1
vol_42=1343488000:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_42_n=1
vol_43=1343516672:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_43_n=1
vol_44=1343553536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_44_n=1
vol_45=1343578112:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_45_n=1
vol_46=1343627264:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_46_n=1
vol_47=1343651840:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_47_n=1
vol_48=1343692800:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_48_n=1
vol_49=1343721472:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_49_n=1
vol_50=1343750144:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_50_n=1
vol_51=1343778816:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_51_n=1
vol_52=1343815680:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_52_n=1
vol_53=1343844352:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_53_n=1
vol_54=1343877120:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_54_n=1
vol_55=1343905792:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_55_n=1
vol_56=1343938560:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_56_n=1
vol_57=1343967232:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_57_n=1
vol_58=1344000000:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_58_n=1
vol_59=1344028672:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_59_n=1
vol_60=1344065536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_60_n=1
vol_61=1344094208:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_61_n=1
vol_62=1344126976:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_62_n=1
vol_63=1344155648:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_63_n=1
vol_64=1344192512:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_64_n=1
vol_65=1344221184:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_65_n=1
vol_66=1344253952:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_66_n=1
vol_67=1344290816:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_67_n=1
vol_68=1344327680:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_68_n=1
vol_69=1344356352:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_69_n=1
vol_70=1344385024:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_70_n=1
vol_71=1344413696:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_71_n=1
vol_72=1344450560:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_72_n=1
vol_73=1344479232:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_73_n=1
vol_74=1344512000:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_74_n=1
vol_75=1344540672:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_75_n=1
vol_76=1344577536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_76_n=1
vol_77=1344614400:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_77_n=1
vol_78=1344647168:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_78_n=1
vol_79=1344675840:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_79_n=1
vol_80=1344708608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_80_n=1
vol_81=1344737280:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_81_n=1
vol_82=1344770048:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_82_n=1
vol_83=1344798720:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_83_n=1
vol_84=1344835584:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_84_n=1
vol_85=1344864256:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_85_n=1
vol_86=1344897024:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_86_n=1
vol_87=1344937984:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_87_n=1
vol_88=1344970752:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_88_n=1
vol_89=1344999424:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_89_n=1
vol_90=1345028096:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_90_n=1
vol_91=1345056768:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_91_n=1
vol_92=1345093632:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_92_n=1
vol_93=1345122304:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_93_n=1
vol_94=1345150976:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_94_n=1
vol_95=1345183744:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_95_n=1
vol_96=1345220608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_96_n=1
vol_97=1345249280:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_97_n=1
vol_98=1345282048:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_98_n=1
vol_99=1345310720:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_99_n=1
vol_100=1345359872:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_100_n=1
vol_101=1345388544:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_101_n=1
vol_102=1345421312:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_102_n=1
vol_103=1345449984:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_103_n=1
vol_104=1345482752:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_104_n=1
vol_105=1345507328:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_105_n=1
vol_106=1345544192:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_106_n=1
vol_107=1345572864:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_107_n=1
vol_108=1345622016:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_108_n=1
vol_109=1345646592:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_109_n=1
vol_110=1345675264:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_110_n=1
vol_111=1345703936:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_111_n=1
vol_112=1345740800:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_112_n=1
vol_113=1345769472:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_113_n=1
vol_114=1345802240:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_114_n=1
vol_115=1345835008:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_115_n=1
vol_116=1345867776:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_116_n=1
vol_117=1345896448:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_117_n=1
vol_118=1345929216:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_118_n=1
vol_119=1345961984:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_119_n=1
vol_120=1345994752:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_120_n=1
vol_121=1346023424:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_121_n=1
vol_122=1346056192:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_122_n=1
vol_123=1346088960:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_123_n=1
vol_124=1346117632:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_124_n=1
vol_125=1346146304:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_125_n=1
vol_126=1346179072:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_126_n=1
vol_127=1346211840:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_127_n=1
vol_128=1346244608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_128_n=1
vol_129=1346285568:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_129_n=1
vol_130=1346310144:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_130_n=1
vol_131=1346342912:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_131_n=1
vol_132=1275084800:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_132_n=1
vol_133=1275113472:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_133_n=1
vol_134=1275142144:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_134_n=1
vol_135=1275170816:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_135_n=1
vol_136=1275215872:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_136_n=1
vol_137=1275240448:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_137_n=1
vol_138=1275269120:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_138_n=1
vol_139=1275297792:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_139_n=1
vol_140=1275330560:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_140_n=1
vol_141=1275359232:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_141_n=1
vol_142=1275387904:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_142_n=1
vol_143=1275416576:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_143_n=1
vol_144=1275449344:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_144_n=1
vol_145=1275478016:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_145_n=1
vol_146=1275506688:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_146_n=1
vol_147=1275535360:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_147_n=1
vol_148=1275568128:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_148_n=1
vol_149=1275596800:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_149_n=1
vol_150=1275625472:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_150_n=1
vol_151=1275654144:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_151_n=1
vol_152=1275686912:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_152_n=1
vol_153=1275715584:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_153_n=1
vol_154=1275744256:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_154_n=1
vol_155=1275772928:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_155_n=1
vol_156=1275805696:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_156_n=1
vol_157=1275846656:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_157_n=1
vol_158=1275879424:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_158_n=1
vol_159=1275908096:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_159_n=1
vol_160=1275940864:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_160_n=1
vol_161=1275969536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_161_n=1
vol_162=1275998208:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_162_n=1
vol_163=1276026880:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_163_n=1
vol_164=1276059648:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_164_n=1
vol_165=1276088320:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_165_n=1
vol_166=1276116992:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_166_n=1
vol_167=1276145664:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_167_n=1
vol_168=1276178432:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_168_n=1
vol_169=1276207104:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_169_n=1
vol_170=1276235776:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_170_n=1
vol_171=1276264448:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_171_n=1
vol_172=1276297216:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_172_n=1
vol_173=1276325888:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_173_n=1
vol_174=1276354560:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_174_n=1
vol_175=1276383232:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_175_n=1
vol_176=1276416000:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_176_n=1
vol_177=1276456960:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_177_n=1
vol_178=1276481536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_178_n=1
vol_179=1276510208:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_179_n=1
vol_180=1276542976:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_180_n=1
vol_181=1276571648:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_181_n=1
vol_182=1276600320:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_182_n=1
vol_183=1276628992:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_183_n=1
vol_184=1276661760:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_184_n=1
vol_185=1276690432:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_185_n=1
vol_186=1276719104:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_186_n=1
vol_187=1276747776:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_187_n=1
vol_188=1276792832:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_188_n=1
vol_189=1276821504:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_189_n=1
vol_190=1276850176:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_190_n=1
vol_191=1276878848:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_191_n=1
vol_192=1276911616:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_192_n=1
vol_193=1276940288:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_193_n=1
vol_194=1276968960:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_194_n=1
vol_195=1276997632:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_195_n=1
vol_196=1277030400:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_196_n=1
vol_197=1277059072:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_197_n=1
vol_198=1277100032:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_198_n=1
vol_199=1277124608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_199_n=1
vol_200=1277157376:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_200_n=1
vol_201=1277186048:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_201_n=1
vol_202=1277214720:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_202_n=1
vol_203=1277243392:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_203_n=1
vol_204=1277284352:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_204_n=1
vol_205=1277308928:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_205_n=1
vol_206=1277341696:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_206_n=1
vol_207=1277370368:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_207_n=1
vol_208=1277403136:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_208_n=1
vol_209=1277431808:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_209_n=1
vol_210=1277460480:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_210_n=1
vol_211=1277489152:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_211_n=1
vol_212=1277521920:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_212_n=1
vol_213=1277550592:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_213_n=1
vol_214=1277579264:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_214_n=1
vol_215=1277607936:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_215_n=1
vol_216=1277640704:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_216_n=1
vol_217=1277669376:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_217_n=1
vol_218=1277710336:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_218_n=1
vol_219=1277734912:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_219_n=1
vol_220=1277767680:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_220_n=1
vol_221=1277796352:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_221_n=1
vol_222=1277825024:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_222_n=1
vol_223=1277853696:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_223_n=1
vol_224=1277886464:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_224_n=1
vol_225=1277915136:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_225_n=1
vol_226=1277943808:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_226_n=1
vol_227=1277972480:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_227_n=1
vol_228=1278017536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_228_n=1
vol_229=1278046208:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_229_n=1
vol_230=1278074880:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_230_n=1
vol_231=1278103552:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_231_n=1
vol_232=1278136320:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_232_n=1
vol_233=1278164992:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_233_n=1
vol_234=1278193664:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_234_n=1
vol_235=1278222336:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_235_n=1
vol_236=1278255104:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_236_n=1
vol_237=1278291968:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_237_n=1
vol_238=1278320640:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_238_n=1
vol_239=1278349312:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_239_n=1
vol_240=1278382080:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_240_n=1
vol_241=1278410752:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_241_n=1
vol_242=1278439424:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_242_n=1
vol_243=1278468096:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_243_n=1
vol_244=1278500864:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_244_n=1
vol_245=1278529536:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_245_n=1
vol_246=1278558208:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_246_n=1
vol_247=1278590976:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_247_n=1
vol_248=1278631936:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_248_n=1
vol_249=1278660608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_249_n=1
vol_250=1278689280:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_250_n=1
vol_251=1278717952:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_251_n=1
vol_252=1278750720:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_252_n=1
vol_253=1278779392:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_253_n=1
vol_254=1278808064:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_254_n=1
vol_255=1278840832:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_255_n=1
vol_256=1278881792:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_256_n=1
vol_257=1278906368:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_257_n=1
vol_258=1278935040:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_258_n=1
vol_259=1278967808:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_259_n=1
vol_260=1278996480:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_260_n=1
vol_261=1279025152:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_261_n=1
vol_262=1279053824:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_262_n=1
vol_263=1279086592:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_263_n=1
vol_264=1279115264:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_264_n=1
vol_265=1279143936:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_265_n=1
vol_266=1279172608:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_266_n=1
vol_267=1279205376:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_267_n=1
vol_268=1279234048:119184225:4096:32768:8192:29802496:256:0:32:0:1:2:3:1:0
vol_268_n=1
sblks="269;0x800:0,0x4c004400:132,0x4c00b400:133,0x4c012400:134,0x4c019400:135,0x4c024400:136,\
0x4c02a400:137,0x4c031400:138,0x4c038400:139,0x4c040400:140,0x4c047400:141,0x4c04e400:142,\
0x4c055400:143,0x4c05d400:144,0x4c064400:145,0x4c06b400:146,0x4c072400:147,0x4c07a400:148,\
0x4c081400:149,0x4c088400:150,0x4c08f400:151,0x4c097400:152,0x4c09e400:153,0x4c0a5400:154,\
0x4c0ac400:155,0x4c0b4400:156,0x4c0be400:157,0x4c0c6400:158,0x4c0cd400:159,0x4c0d5400:160,\
0x4c0dc400:161,0x4c0e3400:162,0x4c0ea400:163,0x4c0f2400:164,0x4c0f9400:165,0x4c100400:166,\
0x4c107400:167,0x4c10f400:168,0x4c116400:169,0x4c11d400:170,0x4c124400:171,0x4c12c400:172,\
0x4c133400:173,0x4c13a400:174,0x4c141400:175,0x4c149400:176,0x4c153400:177,0x4c159400:178,\
0x4c160400:179,0x4c168400:180,0x4c16f400:181,0x4c176400:182,0x4c17d400:183,0x4c185400:184,\
0x4c18c400:185,0x4c193400:186,0x4c19a400:187,0x4c1a5400:188,0x4c1ac400:189,0x4c1b3400:190,\
0x4c1ba400:191,0x4c1c2400:192,0x4c1c9400:193,0x4c1d0400:194,0x4c1d7400:195,0x4c1df400:196,\
0x4c1e6400:197,0x4c1f0400:198,0x4c1f6400:199,0x4c1fe400:200,0x4c205400:201,0x4c20c400:202,\
0x4c213400:203,0x4c21d400:204,0x4c223400:205,0x4c22b400:206,0x4c232400:207,0x4c23a400:208,\
0x4c241400:209,0x4c248400:210,0x4c24f400:211,0x4c257400:212,0x4c25e400:213,0x4c265400:214,\
0x4c26c400:215,0x4c274400:216,0x4c27b400:217,0x4c285400:218,0x4c28b400:219,0x4c293400:220,\
0x4c29a400:221,0x4c2a1400:222,0x4c2a8400:223,0x4c2b0400:224,0x4c2b7400:225,0x4c2be400:226,\
0x4c2c5400:227,0x4c2d0400:228,0x4c2d7400:229,0x4c2de400:230,0x4c2e5400:231,0x4c2ed400:232,\
0x4c2f4400:233,0x4c2fb400:234,0x4c302400:235,0x4c30a400:236,0x4c313400:237,0x4c31a400:238,\
0x4c321400:239,0x4c329400:240,0x4c330400:241,0x4c337400:242,0x4c33e400:243,0x4c346400:244,\
0x4c34d400:245,0x4c354400:246,0x4c35c400:247,0x4c366400:248,0x4c36d400:249,0x4c374400:250,\
0x4c37b400:251,0x4c383400:252,0x4c38a400:253,0x4c391400:254,0x4c399400:255,0x4c3a3400:256,\
0x4c3a9400:257,0x4c3b0400:258,0x4c3b8400:259,0x4c3bf400:260,0x4c3c6400:261,0x4c3cd400:262,\
0x4c3d5400:263,0x4c3dc400:264,0x4c3e3400:265,0x4c3ea400:266,0x4c3f2400:267,0x4c3f9400:268,\
0x50000400:1,0x50007400:2,0x5000f400:3,0x50017400:4,0x5001e400:5,0x50025400:6,0x5002d400:7,\
0x50038400:8,0x5003d400:9,0x50044400:10,0x5004c400:11,0x50055400:12,0x5005c400:13,\
0x50062400:14,0x5006a400:15,0x50073400:16,0x50079400:17,0x50081400:18,0x50089400:19,\
0x50095400:20,0x5009e400:21,0x500a4400:22,0x500ad400:23,0x500b5400:24,0x500bc400:25,\
0x500c4400:26,0x500cb400:27,0x500d6400:28,0x500dc400:29,0x500e3400:30,0x500ea400:31,\
0x500f4400:32,0x500fa400:33,0x50102400:34,0x5010a400:35,0x50112400:36,0x50119400:37,\
0x50121400:38,0x50127400:39,0x50131400:40,0x50138400:41,0x50140400:42,0x50147400:43,\
0x50150400:44,0x50156400:45,0x50162400:46,0x50168400:47,0x50172400:48,0x50179400:49,\
0x50180400:50,0x50187400:51,0x50190400:52,0x50197400:53,0x5019f400:54,0x501a6400:55,\
0x501ae400:56,0x501b5400:57,0x501bd400:58,0x501c4400:59,0x501cd400:60,0x501d4400:61,\
0x501dc400:62,0x501e3400:63,0x501ec400:64,0x501f3400:65,0x501fb400:66,0x50204400:67,\
0x5020d400:68,0x50214400:69,0x5021b400:70,0x50222400:71,0x5022b400:72,0x50232400:73,\
0x5023a400:74,0x50241400:75,0x5024a400:76,0x50253400:77,0x5025b400:78,0x50262400:79,\
0x5026a400:80,0x50271400:81,0x50279400:82,0x50280400:83,0x50289400:84,0x50290400:85,\
0x50298400:86,0x502a2400:87,0x502aa400:88,0x502b1400:89,0x502b8400:90,0x502bf400:91,\
0x502c8400:92,0x502cf400:93,0x502d6400:94,0x502de400:95,0x502e7400:96,0x502ee400:97,\
0x502f6400:98,0x502fd400:99,0x50309400:100,0x50310400:101,0x50318400:102,0x5031f400:103,\
0x50327400:104,0x5032d400:105,0x50336400:106,0x5033d400:107,0x50349400:108,0x5034f400:109,\
0x50356400:110,0x5035d400:111,0x50366400:112,0x5036d400:113,0x50375400:114,0x5037d400:115,\
0x50385400:116,0x5038c400:117,0x50394400:118,0x5039c400:119,0x503a4400:120,0x503ab400:121,\
0x503b3400:122,0x503bb400:123,0x503c2400:124,0x503c9400:125,0x503d1400:126,0x503d9400:127,\
0x503e1400:128,0x503eb400:129,0x503f1400:130,0x503f9400:131,"
dirs="2;0x1a2400:2:2:0:0:1,0x26c192000:557057:2:0:0:1,"
extntblks="0;"
itable_0="0x1a6500:359:256:0x3:432"
itable_0_i="8;418.0.-1+0.48+0.96+0.144+0.208+0.256+0.304+0.352"
itable_1="0x50006000:432319:256:0x3:95699981"
itable_1_i="309;33118208.112.-1+0.240+0.592+0.784+0.1184+0.1232+0.1584+0.1712+0.2064\
+0.2208+0.2256+0.2640+0.2768+0.3024+0.3248+0.3296+0.3728+0.3776+0.4016+0.4256+0.4512\
+0.4704+0.4768+0.5008+0.5200+0.5264+0.5504+0.5744+0.5792+0.6224+0.6272+0.6528+0.6752\
+0.7008+0.7200+0.7248+0.7504+0.7696+0.7744+0.8000+0.8224+0.8272+0.8704+0.8752+0.8992\
+0.9200+0.9248+0.9520+0.9760+0.10016+0.10208+0.10256+0.10496+0.10736+0.10784+0.11216\
+0.11264+0.11504+0.11712+0.11776+0.12016+0.12208+0.12304+0.12544+0.12784+0.13024\
+0.13232+0.13280+0.13744+0.13808+0.14048+0.14176+0.14304+0.14544+0.14656+0.14800\
+0.15024+0.15168+0.15504+0.15632+0.15760+0.16160+0.16528+0.16672+0.17008+0.17136\
+0.17200+0.17552+0.17680+0.18032+0.18160+0.18288+0.18672+0.19040+0.19152+0.19504\
+0.19632+0.20096+0.20224+0.20576+0.20704+0.20832+0.21216+0.21584+0.21696+0.22064\
+0.22208+0.22256+0.22608+0.22736+0.23088+0.23232+0.23344+0.23712+0.24080+0.24224\
+0.24592+0.24736+0.25072+0.25200+0.25552+0.25696+0.26160+0.26528+0.26656+0.27024\
+0.27136+0.27488+0.27616+0.27968+0.28096+0.28560+0.28944+0.29072+0.29424+0.29552\
+0.29904+0.30032+0.30384+0.30512+0.30944+0.30992+0.31376+0.31504+0.31888+0.32016\
+0.32368+0.32496+0.32848+0.32976+0.33440+0.33824+0.33968+0.34304+0.34432+0.34784\
+0.34912+0.35264+0.35392+0.35824+0.35888+0.36128+0.36384+0.36624+0.36832+0.36896\
+0.37136+0.37344+0.37408+0.37648+0.37840+0.37904+0.38384+0.38640+0.38880+0.38928\
+0.39168+0.39376+0.39424+0.39680+0.39904+0.40160+0.40384+0.40816+0.40864+0.41104\
+0.41312+0.41376+0.41632+0.41840+0.41904+0.42160+0.42352+0.42416+0.42656+0.42880\
+0.43344+0.43600+0.43824+0.43872+0.44112+0.44240+0.44480+0.44528+0.44768+0.44912\
+0.45024+0.45392+0.45760+0.45888+0.46240+0.46368+0.46448+0.46800+0.46912+0.47280\
+0.47408+0.47520+0.47888+0.48256+0.48384+0.48736+0.48880+0.49216+0.49360+0.49712\
+0.49824+0.49952+0.50304+0.50656+0.50784+0.51168+0.51312+0.51376+0.51744+0.51888\
+0.53120+0.53360+0.53856+0.54336+0.54800+0.55264+0.55728+0.56240+0.56752+0.57200\
+0.57664+0.58144+0.58656+0.59120+0.59600+0.60048+0.60512+0.61008+0.61520+0.61984\
+0.62448+0.62912+0.63408+0.63872+0.64336+0.64800+0.65264+0.65776+0.66304+0.66768\
+0.67248+0.67696+0.68160+0.68672+0.69120+0.69584+0.70064+0.70560+0.71072+0.71536\
+0.72000+0.72496+0.72960+0.73456+0.73920+0.74400+0.74848+0.75312+0.75856+0.76320\
+0.76784+0.77264+0.77712+0.78240+0.78704+0.79168+0.79648+0.80144+0.80640+0.81104\
+0.81568+0.82032+0.82496+0.82992+0.83456+0.83952+0.84416+0.84880+0.85424+0.85888\
+0.86352+0.86816+0.87280"
itable_2="0x4c002000:170132:256:0x3:118620674"
itable_2_i="513;2971648.126512.-1+0.127744+0.127792+2457600.126496+0.127408+0.127456\
+0.127552+3807232.126448+0.127120+0.127216+0.127312+0.127632+5.126453+0.127125+0.127221\
+0.127317+0.127637+4608.126458+0.127130+0.127226+0.127322+0.127642+32769.126463+0.127135\
+0.127231+0.127327+0.127647+23844346.0+0.464+0.960+0.1424+0.1888+0.2352+0.2816+0.3344\
+0.3808+0.4272+0.4736+0.5200+0.5696+0.6160+0.6624+0.7136+0.7600+0.8096+0.8592+0.9056\
+0.9520+0.9984+0.10480+0.10944+0.11408+0.11888+0.12384+0.12880+0.13344+0.13856+0.14320\
+0.14688+0.15168+0.15648+0.16096+0.16576+0.17072+0.17568+0.18048+0.18512+0.18976\
+0.19472+0.19920+0.20432+0.20896+0.21360+0.21856+0.22336+0.22832+0.23296+0.23744\
+0.24240+0.24720+0.25216+0.25680+0.26192+0.26640+0.27120+0.27616+0.28080+0.28528\
+0.28992+0.29472+0.29968+0.30480+0.30928+0.31440+0.31904+0.32368+0.32864+0.33328\
+0.33808+0.34272+0.34720+0.35232+0.35680+0.36224+0.36704+0.37216+0.37648+0.38112\
+0.38576+0.39056+0.39504+0.40000+0.40512+0.40992+0.41488+0.41936+0.42432+0.42896\
+0.43376+0.43824+0.44304+0.44784+0.45248+0.45760+0.46256+0.46752+0.47232+0.47712\
+0.48176+0.48640+0.49088+0.49584+0.50048+0.50560+0.51024+0.51536+0.52016+0.52480\
+0.52944+0.53424+0.53872+0.54368+0.54832+0.55344+0.55824+0.56272+0.56736+0.57248\
+0.57712+0.58176+0.58640+0.59104+0.59600+0.60112+0.60592+0.61040+0.61504+0.62032\
+0.62512+0.62992+0.63456+0.63920+0.64416+0.64928+0.65392+0.65872+0.66320+0.66816\
+0.67280+0.67744+0.68240+0.68704+0.69200+0.69712+0.70176+0.70640+0.71104+0.71600\
+0.72064+0.72528+0.73024+0.73488+0.73952+0.74512+0.74960+0.75424+0.75888+0.76352\
+0.76848+0.77312+0.77776+0.78272+0.78736+0.79280+0.79760+0.80224+0.80688+0.81152\
+0.81648+0.82112+0.82576+0.83040+0.83536+0.84032+0.84496+0.84960+0.85424+0.85920\
+0.86384+0.86848+0.87312+0.87776+0.88320+0.88784+0.89248+0.89744+0.90208+0.90672\
+0.91136+0.91600+0.92064+0.92528+0.92912+0.93440+0.93888+0.94384+0.94848+0.95296\
+0.95792+0.96288+0.96752+0.97200+0.97664+0.98240+0.98688+0.99152+0.99600+0.100064\
+0.100576+0.101072+0.101520+0.101984+0.102448+0.102976+0.103472+0.103936+0.104384\
+0.104864+0.105312+0.105824+0.106320+0.106768+0.107248+0.107760+0.108256+0.108704\
+0.109168+0.109632+0.110112+0.110608+0.111056+0.111536+0.112000+0.112560+0.113056\
+0.113504+0.113984+0.114448+0.114912+0.115424+0.115856+0.116336+0.116784+0.117312\
+0.117824+0.118256+0.118768+0.119216+0.119680+0.120176+0.120640+0.121120+0.121584\
+0.122032+0.122528+0.123008+0.123456+0.123920+0.124384+0.128432+0.128704+0.128896\
+0.128960+0.129216+0.129328+0.129440+0.129680+0.129920+0.130176+0.130336+0.130448\
+0.131024+0.131312+0.131536+0.131792+0.131984+0.132032+0.132272+0.132480+0.132544\
+0.132800+0.133008+0.133056+0.133488+0.133552+0.133792+0.133984+0.134048+0.134288\
+0.134416+0.134544+0.134768+0.134912+0.135024+0.135264+0.135424+0.135552+0.135904\
+0.136256+0.136400+0.136768+0.136912+0.136960+0.137312+0.137456+0.137792+0.137920\
+0.138048+0.138432+0.138800+0.138928+0.139264+0.139408+0.139760+0.139888+0.140224\
+0.140352+0.140480+0.140864+0.141248+0.141376+0.141728+0.141856+0.141920+0.142288\
+0.142400+0.142752+0.142880+0.143008+0.143408+0.143760+0.143888+0.144224+0.144352\
+0.144720+0.144832+0.145168+0.145328+0.145744+0.145872+0.146224+0.146368+0.146432\
+0.146768+0.146896+0.147248+0.147376+0.147840+0.148224+0.148368+0.148704+0.148832\
+0.149184+0.149312+0.149664+0.149792+0.150256+0.150304+0.150688+0.150816+0.151168\
+0.151296+0.151376+0.151712+0.151840+0.152192+0.152320+0.152928+0.153248+0.153408\
+0.153760+0.153888+0.154240+0.154368+0.154624+0.154816+0.154864+0.155296+0.155360\
+0.155664+0.155888+0.156144+0.156368+0.156432+0.156672+0.156912+0.157168+0.157392\
+0.157856+0.158144+0.158368+0.158608+0.158816+0.158864+0.159104+0.159312+0.159376\
+0.159600+0.159840+0.160272+0.160336+0.160608+0.160864+0.160928+0.161168+0.161392\
+0.161440+0.161680+0.161920+0.162176+0.162400+0.162832+0.162896+0.163152+0.163360\
+0.163408+0.163648+0.163776+0.163904+0.164144+0.164272+0.164416+0.164656+0.164784\
+0.164896+0.165296+0.165696+0.165792+0.165856+0.166208+0.166336+0.166688+0.166832\
+0.167184+0.167296+0.167424+0.167792+0.168160+0.168288+0.168640+0.168768+0.169120\
+0.169264+0.169600+0.169760+0.169888+64847872.124720+0.125024+0.125744+0.126032+0.126272\
+0.126368+1.124721+0.125025+0.125745+0.126033+0.126273+0.126369+2326527.126544+32768.126560\
+557056.126400+262144.126432+1310720.126416+4259840.126576+4489216.126464+1.126465\
+2818047.126480+2064384.126384+0.126624+0.126672+0.126768+0.126816+0.126864+0.127008\
+1146880.126528+0.127840+0.127904+0.127952+0.128000+0.128096+0.128144+0.128192+0.128240"
[ntfsscan3.1]
scan_vorg=3.3
scan_flags=0x3
mftsortcol=0
mftsortrev=0
mftcheckmask=0x22c
mftfiltminlen=0
mftfiltofs=0x0-0x0
mftfiltnum=0-0
MFT_frags_number=0
INDX_recs="0;"
INDX_recs_times=0
INDX_ofs="0;"
volstartstotnum=0
volstarts="9;0x7e00:1:0x2,0x400:1:0x2,0x65f9000:1:0x2,0x46992000:1:0x2,0x71f04f4000:1:0x2,\
0x7470987e00:1:0x2,0x65f9a00:1:0x2,0x4cf00000:1:0x2,0x71f04f4e00:1:0x2,"
volstartsother=0
maxmftnumallow=2147483647
maxvolsize=0x7470c06000
volumes_number=0
volumeselected=-1
volumesortcol=1
Posted: November 8th, 2015, 7:37
by Rollo
Oh dear! windows disk management can't see the drive anymore. I think that probably means that the flaw is mechanical and all is lost!
Posted: November 8th, 2015, 7:43
by Spildit
Hi there !
This is why you should NEVER play with the problematic disk and the first thing to do should be a CLONE of your drive to another drive because in the case you mess the recovery up you can allways go back to the initial drive and hopefully clone it again.
What is the drive model ? Is the ST3500312CS one ?
Does the drive still detects on the BIOS ? Can you still see the S.M.A.R.T. report for that drive ?
Posted: November 8th, 2015, 7:50
by Spildit
If it's the Seagate Pipeline you can consider yourself "lucky" to be able to access it directly on the computer as drives from "Humax" machines normally are "LOCKED" to that device (drive firmware is specially edited to work on the HUMAX and NOT on the PC).
Also working by USB is NOT GOOD AT ALL.
Plug the drive directly to SATA and if the BIOS stills "see" the drive attemp to clone it with ddrescue or prosoft media tools to another drive with the same size. Then you can attempt to continue the recovery process from there.
If you still can't do so and if you need the data the only option left is to send the drive to a data recovery firm (reputable one, not the computer repair shop) and let them handle the case.
If the drive is still working it shouldn't be that expensive ...
Posted: November 8th, 2015, 17:50
by Rollo
I formatted the first partition of the drive as NTFS from a boot disk and Windows disk management sees it again, but Windows Explorer still can't see it although the chime goes off when it is connected.
Posted: November 8th, 2015, 18:00
by Rollo
To Spildit - even tho I checked for replies all day yesterday and the day before, I didn't get an email notification and didn't see your replies until now.
Seagate is the drive model ? It is the ST3500312CS
To "Plug the drive directly to SATA" does that mean opening up the case and looking for another SATA connector?
I've extracted DDRESCUE but don't know how to run it. Do I make it into a iso or image and burn it to CD?
Posted: November 8th, 2015, 19:02
by Spildit
At this point i would say that if you REALLY need to recover the data from your drive you should consider to send it out to a professional data recovery service ...
You already messed it further by formatting the partition in NTFS ... Also you don't know how to clone the drive ...
You might want to read this if you still want to attempt the do-it-yourself route ...
http://www.hddoracle.com/viewtopic.php?f=117&t=1160
And then attempt to extract data from the clone ...
Regards and good luck.
Posted: November 8th, 2015, 21:58
by Rollo
I left a "?" in my answer to the question above- "Seagate is the drive model ? It is the ST3500312CS" . There should be no question mark, it is a Seagate
