| lenovo released latest FW for various laptop hdds http://forum.hddguru.com/viewtopic.php?f=7&t=32310 |
Page 1 of 1 |
| Author: | longlife [ November 14th, 2015, 22:15 ] |
| Post subject: | lenovo released latest FW for various laptop hdds |
Lenovo has released latest FW for their branded hdds. Recently released FWSH46. link http://support.lenovo.com/in/hi/downloads/ds003740 But this fw can be used/forced to upgrade non-lenovo hdds also. Which is very convenient method. some examples was previously discussed in hdd furms also, like in c:\firmware\seagate>HFSS108.exe -P1 5421lv17.LOD for all seagate ST9320325as ( FW upgarde only) May request GURUS of HDDGURU forum to discuss about other hdd models. Hitachi models need emphasis. I know splidit and Fzabkar will be in the frontline. Others are most welcome. |
| Author: | longlife [ November 15th, 2015, 0:42 ] |
| Post subject: | Re: lenovo released latest FW for various laptop hdds |
Still i feel that the Soft is useful to some fellows. |
| Author: | fzabkar [ November 15th, 2015, 3:00 ] |
I would not use OEM firmware to update retail firmware on a Seagate drive. Even two retail firmware versions for the same model may not be compatible. For example, using SDxx firmware to update a 7200.11 with CCxx firmware will render the drive inoperable. There was also a case in this forum where a Seagate user updated a retail drive with Dell firmware, or vice versa. The result was corrupt SMART data, but the drive appeared to be OK in other respects. I have also seen disasters involving Dell firmware updates to Samsung drives, rendering the drive inoperable. |
| Author: | Amarbir[CDR-Labs] [ November 16th, 2015, 15:34 ] |
fzabkar wrote: I would not use OEM firmware to update retail firmware on a Seagate drive. Even two retail firmware versions for the same model may not be compatible. For example, using SDxx firmware to update a 7200.11 with CCxx firmware will render the drive inoperable. There was also a case in this forum where a Seagate user updated a retail drive with Dell firmware, or vice versa. The result was corrupt SMART data, but the drive appeared to be OK in other respects. I have also seen disasters involving Dell firmware updates to Samsung drives, rendering the drive inoperable. Well, And i Wonder Why They Have Two Firmwares For Same Drives .No Me There is No Specific Reason and No Enhancement To Drive Features Also |
