| Upgrading storage for CCTV camera package. http://forum.hddguru.com/viewtopic.php?f=7&t=32893 |
Page 1 of 1 |
| Author: | titusjob [ February 11th, 2016, 9:34 ] |
| Post subject: | Upgrading storage for CCTV camera package. |
I use a 8 channel DVR package for my house, which is only under surveillance during the daytime, in terms of duration its approximately 6 hours at most.since I bought them not for a 24 x 7 surveillance, I had only 1TB of storage when I bought it from Canadian Security Professionals in Ontario. But now I want to upgrade my security system storage since I will be going for a week long 24 x 7 surveillance. The camera stream is H.264, 2 megapixel (1600 x 1200) cameras and recording 21 fps.Can anyone suggest me the optimum amount of storage ( DVR HDD ) required ? |
| Author: | jermy [ February 11th, 2016, 9:43 ] |
| Post subject: | Re: Upgrading storage for CCTV camera package. |
I don't know if you noticed, but this is a data recovery forum |
| Author: | einstein9 [ February 11th, 2016, 12:00 ] |
you don`t need HD recording, reduce the recorded Quality and you will be fine i never liked IP camera`s anyway. Ref. http://www.dvrsystems.net/calc.html http://www.supercircuits.com/resources/ ... calculator good luck |
| Author: | titusjob [ February 11th, 2016, 12:38 ] |
einstein9 wrote: you don`t need HD recording, reduce the recorded Quality and you will be fine i never liked IP camera`s anyway. Ref. http://www.dvrsystems.net/calc.html http://www.supercircuits.com/resources/ ... calculator good luck Thank You I really appreciate for your response.I have calculated the amount of storage required. I guess its above 4TB. So any recommendations you have for the best HDD ? In terms of brand, speed etc.? |
| Author: | warnerr [ February 15th, 2016, 9:26 ] |
hgst: example... such as HGST Deskstar NAS H3IKNAS30003272SN (0S03660) 3TB. You will discover that real time video can take take days to review. We set our systems to record events- that is motion with a bit before and after. Your one terrace drive may be capable of recording months depending on the amount of activity. |
| Author: | einstein9 [ February 15th, 2016, 9:56 ] |
titusjob wrote: einstein9 wrote: you don`t need HD recording, reduce the recorded Quality and you will be fine i never liked IP camera`s anyway. Ref. http://www.dvrsystems.net/calc.html http://www.supercircuits.com/resources/ ... calculator good luck Thank You I really appreciate for your response.I have calculated the amount of storage required. I guess its above 4TB. So any recommendations you have for the best HDD ? In terms of brand, speed etc.? WD Nasware (RED) OR set uour DVR to backup (export) old recording to external NAS (depends on how good/bad is ur DVR) |
