Need help free firmware for Toshiba & Hitachi Data Recovery
Posted: February 20th, 2016, 10:30
by charithaj
I have baught a USB to Serial converter and has Seagate & WD firmware . But still couldn't find a working firmware to Toshiba & Hitachi HDD's . Please help me to find solution..
CharithaJ
Re: Need help free firmware for Toshiba & Hitachi Data Reco
Posted: February 20th, 2016, 10:39
by labtech
The converter stores firmware? Never heard of that before.
What are tryint to accomplish exactly?
Posted: February 20th, 2016, 11:30
by charithaj
HI
Highly appreciate your feed back, It is actually the device which is connect to Rx,Tx & Ground jumpers of the hard disk & connect the device into usb port and working F3 commands for Seagate.
Posted: February 20th, 2016, 13:52
by charithaj
Thanks you very much for your information. Highly appreciate.
Posted: February 21st, 2016, 16:34
by jermy
@Spildit, PC3K allows you access to WD drives to ROM, SA and user data using TTL.
Posted: February 21st, 2016, 23:06
by jermy
sorry, my mistake, I thought you meant it can't be done
Posted: February 22nd, 2016, 12:00
by data-medics
jermy wrote:@Spildit, PC3K allows you access to WD drives to ROM, SA and user data using TTL.
Actually even PC-3000 can't read WD SA via TTL, rather it uses vendor specific ATA commands through SATA. Only read/writes ROM using TTL in boot ROM code mode.
Posted: February 22nd, 2016, 17:47
by jermy
you have a PC3K ?
try it (WDC Marvell USB/COM utility)
hint: I already tried
Posted: February 24th, 2016, 6:36
by charithaj
Thanks for the all information. As a beginner im looking for firmware app + device at lower cost than MRT or PC3K. Can any one give me an indication where can I buy?
Charitha
