| AutoCAD INTERNAL ERROR http://forum.hddguru.com/viewtopic.php?f=7&t=33223 |
Page 1 of 1 |
| Author: | AkseliJaakkola [ April 5th, 2016, 10:51 ] |
| Post subject: | AutoCAD INTERNAL ERROR |
Hi Exports, I just tried to open an AutoCAD file it opened fine then 45 seconds later I get an "AutoCAD LT Error Aborting" Says: "INTERNAL ERROR: !U:\global\src\corecad\coresrc\laymgr.cpp@955: eLock VIolation" Having Saved the file to the desktop the error message became: Fatal Error: Unhandled Access Violation Reading 0x0040 Exception at 6bf87eh What does this mean and how do I overcome it to be able to view the file? Thanks! |
| Author: | HaQue [ April 5th, 2016, 11:38 ] |
| Post subject: | Re: AutoCAD INTERNAL ERROR |
sounds like a weird file lock issue. AutoCAD crashed, then when going back in, thought the file was in use.. or something like it. have you tried rebooting the pc? I hope you backup your files if they are important and not easily recreated. some sort of file versioning is advisable if you are working on CAD / Image / Video processing where projects are worked on for lengthy periods. Windows has file shadow copies that can help.. maybe not this instance, but in future. |
