Post new topic Reply to topic  [ 239 posts ]  Go to page Previous  1 ... 7, 8, 9, 10, 11, 12  Next
 Post subject: Re: HDDSuperClone - A new Linux hard drive cloning/imaging t
PostPosted: January 29th, 2021, 10:10
I've haven't used MRT for quite a while now. The support was hopeless. However, it sounds an interesting development you are working on.
PostPosted: January 29th, 2021, 14:19
Which Linux distro you advice to work with HddSuperClone? I would like to have one installed not a portable version. I noticed you disabled auto mount in the livecd, does HddSuperClone mounts the drives automatically when cloning?
Just curious if whatever Linux I choose if I disable auto mount, it will work without any problem.
I'm new to Linux, so sorry for noob questions.
PostPosted: January 29th, 2021, 16:41
It is always best to clone/image a drive when it is not mounted, as you don't want the OS interfering. And is always best to have automount disabled when working with failing disks, again to keep the OS from interfering. HDDSuperClone does not mount the drive at all. Whatever Linux flavor you choose should work, but you should know how to turn off automount for it as a best practice. The worst case is you can manually unmount a drive if needed, but it is best to not have it mount in the first place. I prefer Xubuntu, but that is my personal preference. There are other reasons for my choice, but they involve the program building and compiling process, not program operation.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: January 29th, 2021, 17:03
Ok, thank you for clarifying.
PostPosted: February 8th, 2021, 23:25
New version released.
HDDSuperClone Changelog
version 2.2.22 20210207
* Added direct relay support for YEPKIT YKUSH series USB switchable hubs
PostPosted: March 21st, 2021, 21:51
version 2.2.23 20210320
* Fixed a bug with the min skip size when updating clone settings
* Updated the main window relay button labels to power on/off
* Log resets now create a time stamped backup
PostPosted: May 5th, 2021, 14:25
maximus, do you still have the discount deal with DMDE?
Thanks.
PostPosted: May 5th, 2021, 15:42
Seems so http://www.hddsuperclone.com/sitev1/hddsuperclone/dmde
PostPosted: July 10th, 2021, 12:58
Hi guys, looking for to get a PCIe SATA expansion card, just to have more SATA ports, are there any specific requirements working with Hddsuperclone, or any regular card would theoretically work?
Thank you.
PostPosted: July 10th, 2021, 14:43
Any regular card should work. As long as it doesn't require a special driver, or has some fancy capabilities (which would most likely require a special driver), then it should work. If it is plug and play, then is should work just the same as any built in SATA ports.
PostPosted: August 6th, 2021, 20:57
version 2.2.24 20210801
* Added the option Fix Driver Memory Error
* Added the option Retry connecting on failure after relay power cycle
* Added the option Max read rate (kB/s)
* The free version now allows a sector size of 4096
HDDLiveCD changelog
2021_08_01
Updated HDDSuperClone to version 2.2.24
Updated hdparm to version 9.62
Added NVMe-CLI (64 bit ISO only)
Added Bless Hex Editor
Added wxHexEditor
PostPosted: January 18th, 2022, 20:12
First, since I missed doing a sale for Cyber Monday, I am having a New Years sale, which I will probably end at the end of January. Information is in the HDDSuperClone Purchase area of the website.
New version released. Actually I missed posting about the previous version.
version 2.3.1 20220115
* Internal programming changes mostly for debugging
* Fixed a bug when using the virtual driver with some languages
Added the option Do not perform identify when listing source devices
version 2.3.0 20210912
* Virtual Driver now works with Linux Kernel 5.6+
HDDLiveCD changelog
2022_01_15
Updated HDDSuperClone to version 2.3.1
Updated hdparm to version 9.63
Updated DMDE to version 3.9.0.791
2021_09_12
Updated HDDSuperClone to version 2.3.0
PostPosted: January 24th, 2022, 21:37
version 2.3.2 20220123
* Fixed a bug with Direct USB mode with the Virtual Driver
* Change made to attempt to work with sleeping ports
HDDSCViewer Changelog
version 0.9.beta 20190901
* Added the option Show high time
HDDLiveCD changelog
2022_01_23
Updated HDDSuperClone to version 2.3.2
Updated HDDSCViewer to version 0.9.beta
Updated ddresuce to 1.26
PostPosted: February 22nd, 2022, 13:32
Hello.
I have been using your tool in its free version for a few years and have seen how it has evolved.
I am about to purchase a YKUSH 3 stabilizer USB card and see the results with unstable WD USB drives.
What is the difference between the YKUSH 3 stabilizer card and the DEEPSPAR USB Stabilizer?
Do they do the same?
Do you have any video using the YKUSH 3 with the HDDSUPERCLONE?
On your youtube channel I only see using a relay.
Thanks and regards
PostPosted: February 22nd, 2022, 13:41
YKush is no stabilizer, it's an on/off switch that can be controlled over software. It does not have the firmware / software that USB Stabilizer has, this has to be provided by the software controlling it.
So the software has to detect an error condition and then decide whether a power cycle is needed > send command to YKUSH to power down and then send command to power up again. In this case HDDSuperClone. So it allows you to power cycle, that's it. It's not similar to USB Stabilizer. Once you combine it with HDDSuperClone then you have something like USB Stabilizer.
Ykush sits in path 'host > usb > ykush > usb drive' normally.
PostPosted: February 22nd, 2022, 19:04
To add to this, the only way to get true USB stabilizer like functionality requires using the Direct USB mode (with the relay/YKush). And it is correct that at this time I do not have any videos demonstrating that mode. It has been on my to do list, but I keep forgetting about it as I don't often get questions about it. And when I do get questions and reply, there is no reply back so I don't know if my suggestions worked or not, and then I forget about it again. I will say the timer settings are the key to success, and every case is different.
PostPosted: February 23rd, 2022, 17:08
Well, I want to see that video. If the combination of YKush 3 and hddsuperclone Pro is capable of doing the same thing as the DEEPSPAR stabilizer, I'm interested.
PostPosted: February 23rd, 2022, 20:29
Okay, I will move making videos for the direct usb mode up my list of things to do. But understand that it will likely take a few weeks or more for me to accomplish this. I could have high hopes of only a couple weeks, but usually something happens that delays my plans.
PostPosted: February 24th, 2022, 7:09
I do not mind waiting. :D
PostPosted: February 24th, 2022, 9:32
Just out of curiosity @maximums, do you own DeepSpar USB Stabilizer? Just curious to know how you expect to get stabilizer-like functions if you have nothing with which to compare. It will be interesting to see.
Recovery Force Data Recovery
