| Seagate hdd repair F3T terminal command http://forum.hddguru.com/viewtopic.php?f=7&t=33490 |
Page 1 of 1 |
| Author: | datahdd116 [ May 20th, 2016, 17:51 ] |
| Post subject: | Seagate hdd repair F3T terminal command |
Hello all international friends Today I will share with you the basic commands used for terminal F3T: Command rebuilt slip list(V1) m0,2,1,,,,,22 Command rebuilt g list(V2) m0,2,2,,,,,22 Command rebuilt P list(V3) m0,2,3,,,,,22 Command zero fill with slip list m0,5,1,10,3,,,22 Command zero fill with G list m0,5,2,10,3,,,22 Command zero fill with P list m0,5,3,10,3,,,22 Command format with slip list m0,8,1,10,3,,,22 Command format with G list m0,8,2,10,3,,,22 Command format with P list m0,8,3,10,3,,,22 Command repair bad sector by Slip list m0,D,1,,,,,22 Command repair bad sector by G list m0,D,2,,,,,22 Command repair bad sector by P list m0,D,3,,,,,22 Command format (seacos XF ) by Slip list m0,20,1,,,,,22 Command format(seacos XF) by G list m0,20,2,,,,,22 Command format (seacos XF) by P list (most power full to repair bad sector and red and green blocks) m0,20,3,,,,,22 Comman for erasing of all sector m0,5,1,,,,,22 Comman for formatting hard disk sectors m0,8,2,,,,,22 NOTE : Yes some of the listed commands will ERASE ALL THE USER DATA |
| Author: | sadiq005 [ August 14th, 2016, 13:29 ] |
| Post subject: | Re: Seagate hdd repair F3T terminal command |
Thank you |
