 Post subject: File xlsx corrupt
PostPosted: May 24th, 2016, 7:40
Hello, hav recovered with r-studio a folder with 10 file's xlsx corrupt. There is a solution for fix this errr and reccover files?
tnx
 Post subject: Re: File xlsx corrupt
PostPosted: May 24th, 2016, 8:31
Did you save recovered files on same location where was original files or on different location (disk)?
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: May 24th, 2016, 9:22
We need more information:
1. What was the original problem with the drive?
2. Are you working with a sector-by-sector clone of the drive?
3. Were there any unread sectors?
4. Where did you copy the recovered files?
PostPosted: May 24th, 2016, 18:38
5. Are any of the files 0Kb in size?
PostPosted: May 25th, 2016, 4:01
the drive it works perfectly
No, i use another software for the image byte to byte
Yes
Yes, Last Copy
Yes any file is 0 kb but there are other file > 0kb
can i add an example xlsx recovered file for help me?
tnx
PostPosted: May 25th, 2016, 11:05
So, yeah.. basically, what is needed a proper hardware imager service to read all the sectors as best as possible.
Can't maximize best outcome with software tools. See a data recovery specialist. Like this will not make progress as there is too much data content missing within each file from the unread sectors.
PostPosted: June 28th, 2016, 11:07
You can try this:
1) Make a copy of the file
2) Rename the copy, giving it a "zip" extension.
3) Try to open the zip archive and see if there are files inside.
4) If the zip does not open, you can try repairing it with Zip Repair Pro (www.ziprepair.com)
5) Try to compare the content of the archive with a previous version of the same file (also renamed as ".zip")
or if not available, with another ".xlsx", to see if some files are lacking in it.
6) Extract the lacking files from the valid archive and add them to to the corrupted one.
7) Rename the modified archive back from ".zip" to ".xlsx"
Another approach, sometimes more efficient, is to perform file carving to extract same or older versions of the xlsx file from unallocated areas.
