| Any new informations for repair Bad internal ROM in WD PCB's http://forum.hddguru.com/viewtopic.php?f=7&t=33698 |
Page 1 of 1 |
| Author: | pikus_09 [ June 28th, 2016, 8:15 ] |
| Post subject: | Any new informations for repair Bad internal ROM in WD PCB's |
Any new informations, or methods, for WD internal ROM pcb like 701499, 701640, 701537? Because i have a few PCb in bad internal rom, and sediv and wd marvel are not support repair BAD internal ROM, previous methods are not helpful, because drives are not locate in external rom, or not propertly initialize. Understand me? |
| Author: | SOSdonnees [ June 28th, 2016, 8:52 ] |
| Post subject: | Re: Any new informations for repair Bad internal ROM in WD P |
Hi, Look at the answer from fzabkar (2nd message in this thread) and the links he provides: http://hddoracle.com/viewtopic.php?f=3&t=1619 Does this help ? |
| Author: | pikus_09 [ June 28th, 2016, 9:07 ] |
No this theard is not helpful. I want to know if are there any new information on the repairs of internal ROM. |
| Author: | einstein9 [ June 28th, 2016, 10:26 ] |
pikus_09 wrote: Any new informations, or methods, for WD internal ROM pcb like 701499, 701640, 701537? Because i have a few PCb in bad internal rom, and sediv and wd marvel are not support repair BAD internal ROM, previous methods are not helpful, because drives are not locate in external rom, or not propertly initialize. Understand me? This is too old my dear, here is a sample solution: 701499 Solder ROM chip on its place (prefer if you Program it with Programmer with its Match ROM i.e. Write Denali Family ROM) Remove Both R13 & R6 701640 Solder ROM chip on its place, same steps as 701499 ADD 22k resister to R74 Connect and your done hope this helps Good luck |
| Author: | pikus_09 [ June 28th, 2016, 10:50 ] |
einstein9 wrote: This is too old my dear, here is a sample solution: Work, fine.701499 Solder ROM chip on its place (prefer if you Program it with Programmer with its Match ROM i.e. Write Denali Family ROM) Remove Both R13 & R6 einstein9 wrote: 701640 Not work. and all methods not work, all checked.
Solder ROM chip on its place, same steps as 701499 ADD 22k resister to R74 Connect and your done |
| Author: | einstein9 [ June 29th, 2016, 7:34 ] |
pikus_09 wrote: einstein9 wrote: This is too old my dear, here is a sample solution: Work, fine.701499 Solder ROM chip on its place (prefer if you Program it with Programmer with its Match ROM i.e. Write Denali Family ROM) Remove Both R13 & R6 einstein9 wrote: 701640 Not work. and all methods not work, all checked.Solder ROM chip on its place, same steps as 701499 ADD 22k resister to R74 Connect and your done for the 701640, Did you try Diff. types of ROM chip (SST, Winbond) ? am refering to my old notes, its been long time really |
| Author: | pikus_09 [ June 29th, 2016, 16:48 ] |
einstein9 wrote: for the 701640, Did you try Diff. types of ROM chip (SST, Winbond) ? well, checked in SST 25FL20, and Winbond 25X20result is such einstein9 wrote: am refering to my old notes, its been long time really Ok, no problem.
