This is bad... right (failing hard drive?)
http://forum.hddguru.com/viewtopic.php?f=7&t=34097
Author:  Established301 [ September 1st, 2016, 4:02 ]
Post subject:  This is bad... right (failing hard drive?)
I have inspiron 7737 and diagnostic tools seem to say the hard drive is bad.
Author:  labtech [ September 10th, 2016, 16:12 ]
Post subject:  Re: This is bad... right (failing hard drive?)
Yes, began failing.
Do you need data from it?
Author:  Amarbir[CDR-Labs] [ September 11th, 2016, 1:05 ]
Hi ,
Copy your Imp Data ,Erase This Drive Get A New One Install os and dump data back to that ,You can also go in for a 250/500 GB SSD or if money is not a issue 1TB SSD
