| HFS Recovery Question http://forum.hddguru.com/viewtopic.php?f=7&t=34149 |
Page 1 of 1 |
| Author: | ddrecovery [ September 14th, 2016, 12:34 ] |
| Post subject: | HFS Recovery Question |
I have a HFS HDD that been reformatted. HFS reformat is usually much more devastating to the file system than say NTFS, but with this recovery I get pretty much all the folder structure and file names but the files are all 0KB and do not open. I have not seen this before? I do get a large chunk of data in RAW however. |
| Author: | data-medics [ September 14th, 2016, 13:04 ] |
| Post subject: | Re: HFS Recovery Question |
What program are you working with to recover it? |
| Author: | ddrecovery [ September 14th, 2016, 13:57 ] |
data-medics wrote: What program are you working with to recover it? Tried most of the popular ones to see if anything changes. UFS Pro, R-Studio and some not so popular ones. All give the same result. |
| Author: | data-medics [ September 14th, 2016, 14:18 ] |
I saw an odd case similar to this once where most files all showed as 512Kb size. I think Data Rescue 4 was able to handle it fairly well though. |
| Author: | pcimage [ September 14th, 2016, 14:49 ] |
Data rescue 3 or 4 running on a Mac usually produces the best results in my experience. |
| Author: | ddrecovery [ September 14th, 2016, 15:16 ] |
data-medics wrote: I saw an odd case similar to this once where most files all showed as 512Kb size. I think Data Rescue 4 was able to handle it fairly well though. I will give it a try and let you know. |
| Author: | ddrecovery [ September 18th, 2016, 14:27 ] |
ddrecovery wrote: data-medics wrote: I saw an odd case similar to this once where most files all showed as 512Kb size. I think Data Rescue 4 was able to handle it fairly well though. I will give it a try and let you know. Worked great, thanks. |
