HDD GURU FORUMS
http://forum.hddguru.com/
HDD Raw copy restore?
http://forum.hddguru.com/viewtopic.php?f=7&t=34266
Page 1 of 1
Author:  Racker_CRO [ October 5th, 2016, 9:43 ]
Post subject:  HDD Raw copy restore?
My SSD drive got some "bad blocks" because of SATA cable failed. I've made a copy with HDD RAW Copy tool to my external USB drive (SSD was in USB enclosure). Data on copy drive is visible and readable. I've zeroed my SSD drive which now doesn't have any bad blocks. When I try to restore data from USB to SSD my system partition on RESTORED drive is RAW....what am I doing wrong (EFI and Recovery partitions seems ok)?
Thank you.
Author:  fzabkar [ October 5th, 2016, 17:14 ]
Post subject:  Re: HDD Raw copy restore?
Could we see the Partitions window in DMDE?
http://dmde.com/
Author:  Racker_CRO [ October 6th, 2016, 5:39 ]
I used EaseUS ToDo Backup to clone my USB drive to my SSD. So far my SSD is readable and I can see all of my data. When I get home I will try to boot form it. I thing drive letter assignment will be the problem. I will report my results here.
Regards.
http://www.phpbb.com/
