HDD GURU FORUMS
http://forum.hddguru.com/
HDDsuperclone help
http://forum.hddguru.com/viewtopic.php?f=7&t=34487
Page 1 of 2
Author:  enito [ November 9th, 2016, 8:38 ]
Post subject:  HDDsuperclone help
im trying to recover a slow read WD hd (applyed all the fixes possibles, mods, etc) and tryed using ddrescue (but so slowwwww take ages) and now trying hddsuperclone.
I get a decent speed,
Source: /dev/sdb Destination: /mnt/2/root/intento2/160gb.img Position: 293631866 Status: Phase1
Total LBA: 312581808 LBA to read: 312581808 Non-tried: 185873840 (7545 areas 59.464062%)
Run time: 0:12:34:21 Remaining: 1:08:39:37 n-divided: 0 (0 areas 0.000000%)
Rate: 2858 KB/s Recent: 808 KB/s Total: 1345 KB/s Bad: 0 (0 areas 0.000000%)
Skip size: 5457 Skips: 7338 Runs: 1049 Resets: 0 Recent: 5457 18 3a 55 c5 f1 45 b9 07 3e f6 4a a2 b3 f0 61 \.:U..E..>.J...a
Position: 301274982 Status: Phase1 bb 98 1d ef 94 6f 2a 89 ca 80 d2 22 03 e3 df U.....o*...."...
Finished: 129028864 (2331 areas 41.278431%) Total LBA: 312581808 LBA to read: 312581808
Non-tried: 182695472 (7833 areas 58.447250%) Rate: 30 MB/s Recent: 974 KB/s Total: 1370 KB/s
Non-trimmed: 857472 (6699 areas 0.274319%) Position: 293691002 Status: Phase1
Non-divided: 0 (0 areas 0.000000%) Non-tried: 185814704 (7546 areas 59.445145%)
Non-scraped: 0 (0 areas 0.000000%) n-divided: 0 (0 areas 0.000000%)
(sorrry for this little bad copy paste)
My question, the skips are big i think, is normal? Phase1 is making, next phases coming can check again the skipped areas?
I run with default setting.
Thx for any tip , greets!
Author:  pclab [ November 9th, 2016, 16:53 ]
Post subject:  Re: HDDsuperclone help
Have you tried to send an email to Scott?
Author:  data-medics [ November 9th, 2016, 18:16 ]
Just a guess, but I'd say you've likely got a bad/weak head and will only get a really partial recovery. Probably will ultimately need a head swap to get a good result.
Author:  enito [ November 9th, 2016, 18:24 ]
Hi thx for replys, can be a damaged head, but now im phase 2, hope i can get some files,
Total LBA: 312581808 LBA to read: 312581808 Run time: 0:22:21:48 Remaining: 4:14:11:55
Rate: 0 B/s Recent: 210 KB/s Total: 915 KB/s Skip size: 8068 Skips: 13792 Runs: 1976 Resets: 0 Recent: 21344
Position: 103587042 Status: Phase2 N Finished: 154060744 (3988 areas 49.286537%)
Non-tried: 156997205 (13354 areas 50.225956%) nNon-trimmed: 1523859 (11908 areas 0.487507%)
Non-divided: 0 (0 areas 0.000000%) Non-scraped: 0 (0 areas 0.000000%)
Author:  enito [ November 9th, 2016, 18:26 ]
whats him email?
thx
Author:  maximus [ November 9th, 2016, 18:48 ]
enito wrote:
whats him email?
thx
Try the contact section of the HDDSuperClone website :)
http://www.sdcomputingservice.com/contact
The skip size is fine, the head skipping algorithm is adjusting it. From what I can tell from the display output the drive looks like it has 2 heads and one is weak/damaged/bad. After phase2 (about 50% recovery in this case) it will get slow. If the rate drops to zero after phase2 then the head is likely dead, but if it still slowly reads data then the head is weak/damaged. But a weak/damaged head could take a long time (days, weeks, months) to image, and very possibly die during the attempt. How valuable is the data?
Author:  enito [ November 9th, 2016, 19:44 ]
maximus wrote:
enito wrote:
whats him email?
thx
Thx for the info. The data is not really valuable, but wanna try to get most data, i think i left the tool try to make some works. We see in phase 3 if i get more info, total are 4 phases and tool stop?
greets
Author:  maximus [ November 9th, 2016, 20:36 ]
Also, the fact that there are more skips than non-trimmed areas indicates that some of the skips were triggered by a slow read (2 seconds default). That is a likely sign the bad head is reading, but without seeing the log I can't be sure. It does not indicate how slow the bad head will read though, or how many errors it has. You won't know that until it gets past phase2.
Author:  maximus [ November 9th, 2016, 21:47 ]
There are actually 6 total phases, after phase4 is trimming, then scraping. See the Theory of Operation section in the manual for more information about the different phases.
http://www.sdcomputingservice.com/hddsu ... -Operation
The thing to watch is the remaining time. It is not in any way fully accurate in situations like this, but it can give you an idea of what to expect. Once you get past phase2 it will give a better idea of the time it may take to finish. Usually the remaining time gets a bit more accurate every time it gets to the next phase, but not until the trimming phase will it give the best estimate.
Author:  enito [ November 10th, 2016, 13:16 ]
Hi,now in phase 3 and so so slowww,
7a 2a 21 60 b1 b4 55 99 96 a7 80 1d 20 bd c7 c0 z*!`..U..... ... 00 00 00 00 00 00 40 00 00 00 c0 03 00 00 01 .......@........
0d 1e 28 00 67 00 c3 05 bd 15 5e 65 5e 00 61 e0 ..(.g.....^e^.a. Total LBA: 312581808 LBA to read: 312581808
06 89 d1 40 03 38 06 0d 77 31 09 91 e0 06 05 e8 ...@.8..w1...... Rate: 2807 B/s Recent: 1148 B/s Total: 595 KB/s
Source: /dev/sdb Destination: /mnt/2/root/intento2/160gb.img Position: 5635221 Status: Phase3
Total LBA: 312581808 LBA to read: 312581808 Non-tried: 153885879 (15867 areas 49.230595%)
Run time: 1:17:10:22 Remaining: 185:18:49:56 n-divided: 0 (0 areas 0.000000%)
Rate: 2811 B/s Recent: 3641 B/s Total: 507 KB/s Bad: 0 (0 areas 0.000000%)
Skip size: 4096 Skips: 17294 Runs: 2296 Resets: 0 Recent: 4096 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Position: 10939757 Status: Phase3 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Finished: 156979339 (5648 areas 50.220242%) Total LBA: 312581808 LBA to read: 312581808
Non-tried: 153723611 (16436 areas 49.178680%) Rate: 0 B/s Recent: 906 B/s Total: 595 KB/s
Non-trimmed: 1878858 (14376 areas 0.601077%) Position: 5635349 Status: Phase3
Non-divided: 0 (0 areas 0.000000%) Non-tried: 153885751 (15867 areas 49.230553%)
Not sure if i left some days? or with this, nothing i cant do?
thx!
Author:  maximus [ November 10th, 2016, 18:30 ]
According to this number it would take 6 months to finish. I said it would be slow after phase2. Phase3 will do smaller skips trying to find areas that read faster, but I think that in this case you will not get much more data from it unless you let it run for a few months, assuming the drive would even last that long. I think it is time to stop and see what files you can recover from the partial image. HDDSuperClone has done what it is designed to do, get the most data from the good head(s) first, but now the bad head is reading so slow that it is not worth it to keep going in this case.
Author:  jermy [ November 10th, 2016, 18:39 ]
Judging by log the OP provided it has 2 heads, which 1 of them is bad/weak.
Unless its small files the OP is looking for, there is no point on trying.
Author:  maximus [ November 10th, 2016, 21:11 ]
That depends on what files. The disk might read about 100MB per head at the beginning and maybe 65MB at the end (basing this on the skip size, although it is an educated guess, maybe someday I will come up with the reverse formulas to correctly calculate this). That could mean possible recovery of some files such as pictures which are only a few MB in size each and would fit in the good head. But I do admit that recovery chances are not good without professional recovery, would be very lucky to get 30% of files at best, likely much less depending on what software is used for the file recovery and the nature of the files, not to mention disk fragmentation. If the OP has a spare computer and the time (months) then they could let the recovery run and see what happens...
Author:  maximus [ November 10th, 2016, 21:20 ]
If the OP does wish to keep going with the recovery, in this case I would suggest to change the cluster size to 1 for the rest of the recovery. With read speeds that slow there is no reason to read larger chunks, only to have to trim and scrape them later.
Author:  enito [ November 10th, 2016, 23:06 ]
Hi i can try some time more, and i add a command to my line and resume?
hddsuperclone -s /dev/sdb -t /mnt/2/root/intento2/160gb.img -f /mnt/2/root/intento2/lala.log
this line im using right now, i scan the file generated:
file 160gb.img
160gb.img: x86 boot sector
dont see partitions table :(
greets!
Author:  maximus [ November 10th, 2016, 23:32 ]
Yes, to continue with a cluster size of 1, add "-c 1" to the command line:
hddsuperclone -s /dev/sdb -t /mnt/2/root/intento2/160gb.img -f /mnt/2/root/intento2/lala.log -c 1
Is this drive connected as USB or directly as SATA/PATA? If connected directly as SATA/PATA then add "--ata" to the command line also. This can help some with error processing time. If USB don't bother with this option, it won't work.
Author:  enito [ November 10th, 2016, 23:42 ]
Right, with c1 --ata i see more activity now, the hd is sata directly conencteroot@lubuntu:/home/lubuntu# hddsuperclone -s /dev/sdb -t /mnt/2/root/intento2/160gb.img -f /mnt/2/root/intento2/lala.log -c 1 --ata
HDDSuperClone 1.3_20161015
Logfile exists, reading it in
Checking progress log file...
65 6c 6c 61 6e 65 6f 75 73 53 79 6d 62 6f 6c 73 ellaneousSymbols
00 78 6d 6c 55 43 53 49 73 4d 69 73 63 65 6c 6c .xmlUCSIsMiscell
61 6e 65 6f 75 73 53 79 6d 62 6f 6c 73 61 6e 64 aneousSymbolsand
Run time: 0:00:02:39 Remaining: 343:22:56:21
Rate: 735 B/s Recent: 2745 B/s Total: 2502 B/s
Skip size: 4096 Skips: 59 Runs: 0 Resets: 0 Recent: 0
Position: 21026668 Status: Phase3
Finished: 157049018 (6131 areas 50.242535%)
Non-tried: 153436177 (17553 areas 49.086727%)
Non-trimmed: 2096607 (15625 areas 0.670739%)
Bad: 6 (6 areas 0.000002%)
But the strange thing i dont see the file image is growing, up..
-rw-r--r-- 1 root root 160041885184 nov 11 03:40 160gb.img
-rw-r--r-- 1 root root 160041885184 nov 11 03:41 160gb.img
Looks the time, and not growing up, insted i see activity in hddsuperclone ..
thx!!
Author:  maximus [ November 19th, 2016, 11:48 ]
The image shouldn't grow because the tool should already had created the image to the full size with zeros or "bad" or whatever pattern filling the space on the image that could not be read on the source drive.
Technically it uses sparse writes. If you write the last sector to the file Linux will show it as full size. But if you use a command that shows actual disk usage, you will see that it is only taking up the space that has been actually written.
du -ah
Author:  maximus [ November 19th, 2016, 12:36 ]
Spildit wrote:
I do have a suggestion for your Cloning tool ! I don't know if you want to implement something like this but it would be nice to have, at least on the paid version.
When you skip bad sectors you might want to reverse clone/image from the point where the skip ends backwards to the first bad block it enconters.
Example - You are cloning a drive and you hit several bad sectors so you skip a pre-defined number of LBAs. If you end up on a sector that is good then instead of moving on to the next LBA you should go back and try to clone/image the prior LBA and so on untill you reach a bad sector. Then you would move forward again. This might help with your bad head calculation algorith as well. let's say that you are imaging from LBA 0 to 1000 and you set a skip of 100 sectors when 5 sectors are bad in a row. If you have LBA 10 to 20 "bad" then your tool will reach LBA 15 and will skip to 115 (or 116 or whatever). then instead of moving on to 117, 118, etc .... it would instead attempt a reverse clone from 115 backwards untill it reach the 20 (that would be the first bad block in reverse from the point you skip). This would maximize the data that you would grab from a big "skip". This is the same that HRT-DRE does (unless you turn it off). If you can implement something like this and if you end up cloning a drive with a bad head it might help you out to skip the head and re-adjust by going back to get the data if the skip ends up on a further point of the working head instead on the first LBA assigned to the working heads.
That is what phase2 does, it copies in reverse with skipping to get any good data that was missed due to being skipped in the forward pass. Also, the self adjusting skipping algorithm does its best not to over skip by too much, meaning it only skips as far as it thinks it needs to. You should try it sometime on a drive with a weak head and watch the pattern it makes (use hddscviewer for the visual reference).
Author:  enito [ November 21st, 2016, 8:41 ]
so many days but only grow 1gb, see
20 74 68 65 73 65 20 64 65 66 61 75 6c 74 73 2c these defaults,
20 74 68 69 73 20 64 72 69 76 65 72 20 77 69 6c this driver wil
6c 20 6d 61 6b 65 20 31 20 68 6f 73 74 20 77 69 l make 1 host wi
Run time: 10:09:03:22 Remaining: 191:14:38:08
Rate: 1174 B/s Recent: 4888 B/s Total: 2046 B/s
Skip size: 4096 Skips: 35891 Runs: 0 Resets: 0 Recent: 0
Position: 6544102 Status: Phase4
Finished: 160632424 (75903 areas 51.388924%)
Non-tried: 149792266 (50458 areas 47.920979%)
Bad: 60511 (48252 areas 0.019358%)
Page 1 of 2 All times are UTC - 5 hours [ DST ]
http://www.phpbb.com/
