| LL Format tool used and now cannot reinstall Win7 OS http://forum.hddguru.com/viewtopic.php?f=7&t=35066 |
Page 1 of 1 |
| Author: | loninappleton [ February 27th, 2017, 15:22 ] |
| Post subject: | LL Format tool used and now cannot reinstall Win7 OS |
The HDD Guru LLFormat was used on an HD I have-- pretty old-- and then I ran the quick format (Simple volume) within Windows 7 as Administrator. The HD is a Western Digital. Does Running the LLF require a setup and initialize from the Western Digital tools as a 'new drive' which Win 7 install will recognize? Please advise on a procedure. |
| Author: | RolandJS [ March 18th, 2017, 8:25 ] |
| Post subject: | Re: LL Format tool used and now cannot reinstall Win7 OS |
Eactly what model is this WD HD? If applicable to this HD: was DriveLock, with or without a user password, used previously? On 2nd thought, a better question: what WD utilities came with this HD? |
| Author: | rogfanther [ March 18th, 2017, 9:30 ] |
After the wiping, windows 7 should just state the disk is unformatted and proceed to install. But you say you ran the Quck Format. That means, after running the llf utility, you created a partition in the drive through windows 7, isn“t it ? If you want to install windows in it, no need to create partition/format beforehand. You can just delete all partition in it from Disk Manager, then proceed to install windows from the cd boot. |
| Author: | giuseppem [ March 30th, 2017, 12:46 ] |
The title is misleading: so you don't have the problem you want an advice. |
