WDMarvel 3.1.1 USB-ATA Pass-Through :
Posted: March 12th, 2017, 14:22
This is AMAZING improvement/upgrade to WDMarvel !!!
Now WDMarvel can work with drives connected by USB adaptors and USB only WD drives as well !!!
This is a screen capture of my test Denali 2.5 drive connected to the system by a GEMBIRD USB to IDE and SATA adaptor :
(As we can see by the screen capture WDMarvel was able to READ ROM and MODULES from my test drive connected by USB adaptor !!!)
Also the new WDMarvel software can work with WD drives by TTL :
WDMarvel keeps getting better and better and it's a MUST HAVE firmware tool for WD drives !!!
Nice work and a fantastic update !
https://wdmarvel.com/en/version-3-1-1-usb/
A full list of changes in the WD Marvel 3.1.1 :
■ In the internal formatting dialog added options to clear translator, G_List, RELO-List
■ Fixed option “Low capacity (DownSize)» in the ARCO process
■ Fixed ARCO process for Diablo3D
■ Added support for the work through the serial port and TTL adapter
■ Added support for the work through USB
■ In the ARCO process added option to automatically filling of the empty values in the model list
■ Fixed error “Parameters of test xxxx not found” for some tests in the ARCO process
■ Fixed an incorrect output of the elapsed time when the systems time format is 12H
■ In ARCO process added manual selection of the ARCO Data offset
■ Added bat files for signing drivers by test certificate and enable test mode in x64 operating systems
■ Now ARCO process does not start WRRO tests if they are already in the SelfScan script
■ In the ARCO process added automatic creation of the heads surface logs, that are absent in donor FW
■ In the ARCO process added selection of the executable overlay for MiniARCO
