 Post subject: HDAT2 resetting of HPA does not persist over power-cycle
PostPosted: May 8th, 2017, 2:07
I am one of those who've fallen victim to Dell's preventing cloning of their laptop drives to larger drives (code in their Master Boot Record sets the drives HPA to the laptop's original drive size). The original drive has 73GB of apparent drive space available. When I cloned the drive to a 256GB SSD and booted, the boot failed and I was left with a 73GB SSD with truncated content.
That's when I learned what HPA is. Using HDAT2, I reset the drive size back to its original 256GB and I cleaned up the boot sectors so that it did not reset the HPA again. After power-cycling the drive, I am now left with 118.62GB! That is more than the 73GB that Dell left me with, but no matter what/how I use HDAT2 to restore the size to 256GB, that only lasts until the next power cycle.
Is there another setting that I might need to set to have the drive retain its full, factory setting?
Is there another tool that I can use (besides MHDD--which I haven't gotten to work) which might reset the HPA properly?
 Post subject: Re: HDAT2 resetting of HPA does not persist over power-cycle
PostPosted: May 8th, 2017, 3:14
http://hddguru.com/software/2007.07.20-HDD-Capacity-Restore-Tool
PostPosted: June 16th, 2017, 9:14
@fzabkar
Hi there,
I have a 'kind off' similer problem. My WD 3TB only shows 801Gb. Read the forums and the best advice given is to use:
http://hddguru.com/software/2007.07.20- ... store-Tool
The only thing is that this freeware app is no longer available :-(
Do you know where I can find this application?
Many thanx
Ips
PostPosted: June 16th, 2017, 12:23
First check your HDD in Disk Manager and see if it show ~2800gb.
And then format your HDD with GPT with full capacity.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: June 16th, 2017, 15:21
ATATool - Windows ATA Disk Info and HPA/DCO Utility:
http://www.datasynergy.co.uk/products/atatool/
Data Synergy ATATool can be used to display and modify ATA disk information from a Microsoft Windows environment.
This does not necessarily mean that the drive's capacity has been cut by a HPA. Instead it usually points to a 32-bit LBA limitation in BIOS or a driver. If the drive is in an external enclosure, then the enclosure's firmware is most likely affected by a 32-bit LBA limitation.
PostPosted: June 16th, 2017, 18:38
Or.. somebody created only a 800gb partition in it
Users browsing this forum: No registered users and 21 guests
